What kind of solder to use for temperature console resistors?
Discussion in 'Technical Chat' started by foampile, Mar 14, 2015.
  1. Mar 14, 2015 at 4:44 PM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    I need to solder a replacement 510 resistor in my temperature console and found these instructions. However, I am unsure which solder to use. I have a pencil 40W soldering iron.
  2. Mar 15, 2015 at 11:14 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Regular 60/40 rosin core solder will do the job. I prefer the thin stuff, .031 dia.
  3. Mar 16, 2015 at 2:48 PM
    azreb
    azreb Geezer
    TN
    FWIW I spent my working days as an electrical engineer. My first thought when I saw your link was that resistor does not see 3 watts. The total 12 volt supply most likely does not appear across it--therefore no 3 watts dissipated. An electrical overstress usually produces smoke, blackening the part. At any rate, those three resistors hung on in his fix should be secured somehow or vibrations will eventually cause a break in a connection.
