What Leaf Springs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tombo131, Mar 4, 2022.
  1. Mar 4, 2022 at 7:48 AM
    tombo131
    tombo131 [OP] Member
    2017 TRD Sport DC LB Quicksand
    Hey all. Somewhat of a newbie with suspension changes. Have a 2017 DCLB TRD Sport, no lift, but I have a lot of extra static weight going on the bed. Fiberglass cap is about 175 pounds, and RTT that is going on soon is looking to be 200+ (diy build).
    I'm assuming I need to upgrade my leaf springs since I'll have around 400 extra pounds on the bed nearly all the time before gear; but not sure where to start.
  2. Mar 4, 2022 at 7:53 AM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Deaver U402 Stage 2
    YF_Ryan and MR E30 like this.
  3. Mar 4, 2022 at 8:08 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Icon rtx
  4. Mar 4, 2022 at 8:14 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Custom built set from Alcan.
    Ha! Good luck choosing.
    Pwl and 71tattooguy like this.
  5. Mar 4, 2022 at 8:19 AM
    tombo131
    Thanks all!
  6. Mar 4, 2022 at 9:02 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I recently put Deaver Stage 2s on my LB and they ride nice with only my topper and gear (300lbs maybe) and also ride great with the 700lbs or so I had in there the other day. No shims or notable vibes either. They do provide some lift though around 2-2.5" when on the lighter end of their rating. I did Eibach Pro stage 2 coilovers up front and have some rake.
    71tattooguy likes this.
  7. Mar 4, 2022 at 9:12 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I love my Deaver U402 Stage 3, but that would be overkill for your needs (unless maybe you want to add a trailer to your setup). Sounds like the Stage 2 would be great for you. The Deavers use a higher number of thinner leaf springs to help give a more gradual spring rate. Ride much better when running light than a standard HD leaf pack with only a few thick leaves. I regularly run an empty bed with the rear end of my truck about 6 inches high, then I'll load up the 1000lb camper in the bed and a loaded 16ft car trailer trailer to bring me back down to level. I love the simplicity of the leaves. No need for airbags (which are another great option for running varying loads).
    tombo131[OP] likes this.
