What Leveling kit do I use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScottyKC, Feb 23, 2010.
  1. Feb 23, 2010 at 8:10 AM
    ScottyKC
    ScottyKC [OP] Well-Known Member
    Scott
    Omaha
    08 Tacoma Sport SR5
    Bilstein 5100 set to 2.5" lift in front. Rear TSB with 1.5" rough country. Bridgestone Dueller Revo2 265/70/17 Satoshi mod, and painted center caps, tinted windows.
    I want to install a leveling kit, there are 1.5", 2", 2.25" and 2.5" available. Which one do I use? I would like to see picture of what other members have done. I haven't decided between just a leveling kit or a 3" lift???
  2. Feb 23, 2010 at 8:13 AM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    5100's or you could get a 19" body lift and run 39.5's.. BTW welcome!
  3. Feb 23, 2010 at 8:24 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    5100 will give you either .85", 1.75" or 2.5" of lift. Very versatile and relatively cheap
  4. Feb 23, 2010 at 8:26 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    LMAO!!!! :rofl:
    x2 I think Billy 5100s are the best way to get rid of a trucks rake :)
  5. Feb 23, 2010 at 9:57 AM
    ScottyKC
    Scott
    Omaha
    08 Tacoma Sport SR5
    Should I install 5100 in fron and rear? Will the rear give me any lift?
  6. Feb 23, 2010 at 10:03 AM
    MOB 08Tacoma
    MOB 08Tacoma Active Member
    whittier ca
    AFE intake,Running Boards,Brush Guard
    Are the 3" ToyTec Spacers any good? Would it look nice if its only the front lifted?
  7. Feb 23, 2010 at 10:03 AM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    have you got the tsb done??
  8. Feb 23, 2010 at 10:04 AM
    08pretaco
    Oliver
    az
    No lift in the rear from them aal or tsb for that
  9. Feb 23, 2010 at 10:05 AM
    ScottyKC
    Scott
    Omaha
    08 Tacoma Sport SR5
    Bought the truck used 1 month ago. Has 20,000 miles. How would I know if the TSB was done?
  10. Feb 23, 2010 at 10:14 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Look at your rear leaf springs. If you have three leafs then you don't have the TSB done. If you have 4 leafs then you do have it.
  11. Feb 23, 2010 at 10:15 AM
    SoutheastTaco
    steven
    columbia sc
    09 trd sport dc 4x4
    look and see if you have three leaf springs or four. tsb is four lifts it about inch and a half
  12. Feb 23, 2010 at 10:16 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Also since yours is an 08 if the TSB was done I believe you would have the updated Bilstein shocks all around.
  13. Feb 23, 2010 at 10:21 AM
    akyota
    akyota Well-Known Member
    Fairbanks, Alaska
    10' DC trd-offroad mag gray
    none yet
    Why on the 08's did they get new Bilstein's? I have a 2010 and got the TSB done, they swapped my billys out for some genaric toyota brand! Anyone know?
  14. Feb 23, 2010 at 10:24 AM
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    I used the Old Man Emu struts (+2.75 inches) and already had 4 leafs in the rear when I bought mine used. I ended up adding a 1" block in the rear because it was slightly lower after the front was raised.
    This method caused vibrations at 35-40 mph, so I did a carrier bearing drop, which madethings moderately better but did not do away with the vibes.
    In my '05 DCab sport, I used an AAL and front spacers, and liked the ride better than what I have now with OME...it was nice and smooth and no vibes.
    My 2006 with OME struts:
    My 2005 with spacers and AAL:
  15. Feb 23, 2010 at 10:26 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    In the 05-08 they swapped the old shocks to the Bilsteins on non-TRD trucks.
    09-10 I believe they don't update the shocks. If you have a TRD OR and they took your Bilsteins maybe they made a mistake. I had the TSB done and they didn't change my shocks, only the rear leafs.
  16. Feb 23, 2010 at 10:28 AM
    akyota
    Fairbanks, Alaska
    none yet
    Thanks, I brought it to there attention when I picked it up but they were so busy with the recall crap they wouldn't find out what they were supposed to do.:confused:
  17. Feb 23, 2010 at 10:30 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Here's the TSB to include 2010 models:
    T-SB-0305-08(2010 Models).pdf
  18. Feb 23, 2010 at 10:34 AM
    akyota
    Fairbanks, Alaska
    none yet
    See what it says though:
    The 2009 – 2010 model year non-TRD Option Package Truck is already equipped with updated​
    shock absorbers and bump stops. Do NOT replace the shock absorbers or bump stops.
  19. Feb 23, 2010 at 10:36 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Right. 09-10 shocks should not be changed according to what the TSB says. That's why I would think the dealer messed up.
  20. Feb 23, 2010 at 10:38 AM
    TacoCat
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    One thing you could do is since it appears they messed up, you could try buying a set of the Bilstein 5100s (good luck finding any in stock) from downsouth motorsports and see if the dealer will install them for you free of charge. It'd be worth a shot to try asking if they would be willing to do that.
