What lift and tire combo should I do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 802, Jan 25, 2014.
  1. Jan 25, 2014 at 9:10 AM
    802 [OP] Well-Known Member
    Rob
    VT
    '13 TRD Off-Road
    Toytec Nitto Ridge Grapplers
    I once again fall to your guys expertise in this matter.
    I've been looking into different lifts, and I have come to a stand still. Should I go with a 3" OME lift and 265/75/16? (I hear that is the biggest tire you can fit, is that true? I would love to get the biggest tires I can fit in there, but I don't want to do to much trimming).
    Or just do Billies all around, with 265's. I know there is quite a difference between the two. But I want to just beef my truck up a little. If I can only fit 265's with the 3" lift, would the tires look to small?
    What have you all got? Thanks!
  2. Jan 25, 2014 at 9:14 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    You can fit 285's with minimal trimming with a full 3" OME. 265's look good with a 2.5" lift which you can do by 5100's or OME. Depends on what you want to do with it and how much you have to spend.
    There are a bunch of threads on the differences and tire sizes for these lifts. Just keep reading and searching and you will find an answer to everything! Haha
  3. Jan 25, 2014 at 9:18 AM
    taco 2011
    taco 2011 Well-Known Member
    Alabama
    2011 Toyota Tacoma TRD SR5
    Westin Bull guard,predator nerf bars, Window Tint Legal limit, Weather tech Floor mats, Weather tech smoke visors, Wet Okole seat covers, OEM Roof Racks, Reverse Camera, Pace Edwards Full Metal Jack Rabbit Cover,Dyno power locking tailgate Trd alloy wheels, Dunlop at tires JL Stealthbox, JL custom fit molding kit, Directed Audio 500 watt amp, LCI adaptor. More mods to come.
    Ik from experience that with 285/65/18 you will have to trim a little. With 265/75/16 you shouldn't need a lift at all. If you are set on the billies i think it will give your truck a much smoother ride and the aggressive look you are going for. You can search around here for 265 with 3 inch lift on them. There is a really good thread somewhere on here.
  4. Jan 25, 2014 at 9:20 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    How much do you want it lifted and how much money do you want to spend?
    3 inches and you will probably want new UCAs to get the alignment right. 1.6 inches, go for eibachs. Billies only and you can set at .85, 1.75. and 2.5. The higher you set with the stock springs, the rougher the ride.
    Tons of reading around the forum. You can also check out the suspension forum.
