What lift and tire size is best for moderate off roading?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Venice Taco, May 4, 2019.
  1. May 4, 2019 at 3:45 PM
    Venice Taco
    Venice Taco [OP] New Member
    Adam
    2019 Cement Tacoma
    None yet
    hi, I’m going to put king suspension on my 2019 Tacoma Off Road and curious to get everyone’s thoughts on the ideal lift and tire size to go along with that.
    I’m looking to just do some moderate off roading, nothing too serious. I also would still like to be able to keep my spare wheel under the truck.
    Is a 2” lift with 275 BFG Ko2s doable?
  2. May 4, 2019 at 3:55 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Where are you wheeling?
    Lots of rocks?
    More important for moderate wheeling are sliders and skid plates. Moderate wheeling in my experience means getting high centered and bringing your truck down on its sliders quite frequently. I wheeled difficult trails on 32s and a 3 inch lift for a long time with armor. I upgraded to 33s and believe it or not that extra 1/2 inch of clearance matters (its a game of inches). If you get Kings they will be adjustable, so choose your height (and learn the ramifications of those heights for your suspension system).
    CygnusX191 and Venice Taco[OP] like this.
  3. May 4, 2019 at 3:57 PM
    ecgreen
    Sean
    OH yeah...and welcome to owning the coolest freekin truck on the planet
  4. May 4, 2019 at 3:59 PM
    Venice Taco
    Adam
    2019 Cement Tacoma
    None yet
    Thanks, I’m definitely getting skid plates over everything except for the fuel tank and sliders.
    I live in Southern California so I’ll be mainly going off roading around Joshua Tree and the sierras up by mammoth lakes.
    Can I fit 33’s under the truck?
  5. May 4, 2019 at 4:05 PM
    ecgreen
    Sean
    I am not a 3rd gen guy, so I am guessing they will chime in. On a 2nd gen, you can fit them, but often need to do a cab mount chop. Also very important is your wheel backspacing - so you don't hit your UCA. A lot of guys use spacers to get the clearance from the UCAs. I went with 255s and a 4.75 inch backspace wheel and I had to do zero modifications.
    Keeping your lift as low as possible is a good idea for a number of reasons. If you go above 2" you'll need new UCAs to get a proper alignment. Plus, you will stress the CVs less, etc, etc. With that being said, 3" is nice, cause it gets your frame up off the rocks. I don't regret my 3" lift. Took more work, but I like the frame clearance.
    Wheeling in Southern California is a mix of everything. You will be amazed how far you can go with your current plan. I do recommend you obsess for awhile and learn everything you can about lifts before you buy.
  6. May 4, 2019 at 4:09 PM
    ecgreen
    Sean
    Also...if yo u are a 4 cyl...pushing 275s without a re-gear is no bueno. 6 cyl youll be fine
  7. May 4, 2019 at 4:21 PM
    Venice Taco
    Adam
    2019 Cement Tacoma
    None yet
    Thank you!
    ecgreen likes this.
  8. May 4, 2019 at 5:29 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
  9. May 4, 2019 at 5:32 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW. The suspension is the lift. You will need a new leaf pack or blocks for the rear to be level or keep factory rake. For sliders... you are local to @Shmellmopwho get a set of his.
  10. May 4, 2019 at 5:55 PM
    JCOOR
    TRD Burglar
    That’s what she said
    ecgreen, THE_KiRRAx and tcjacado like this.
  11. May 4, 2019 at 5:57 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I think it was more like :rofl: you call that 3 inches :rofl:
  12. May 4, 2019 at 6:00 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    ...and 255/85 16's.
    4x4_Angel, Spare Parts and jetroutm like this.
  13. May 4, 2019 at 6:01 PM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yes, but loose the rock dragger up front and the low pro tires are a no go.
    If you want to be off road. Mall crawling works fine with this setup.
    BroID and DaveInDenver like this.
  14. May 4, 2019 at 6:07 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Could we please have a picture of this truck with the rear suspension at full flex?
  15. May 4, 2019 at 6:19 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Thanks Jay!
    @Venice Taco
    If you have any questions about installs or sliders or anything I can help you.
  16. May 4, 2019 at 6:20 PM
    tcjacado
    :hattip:
    Always a rec for the best.
    Shmellmopwho[QUOTED] likes this.
  17. May 4, 2019 at 6:46 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    :cheers:
    CygnusX191 and tcjacado[QUOTED] like this.
  18. May 4, 2019 at 10:00 PM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I must be doing it wrong. I've done some moderate rock crawling in my stock Tacoma.
  19. May 4, 2019 at 10:07 PM
    Bumble Bee Tuna
    Bumble Bee Tuna Well-Known Member
    SoCal
    18 4x4OR M/T
    1 dumb driver
    Yes.
    More roll, less scroll.
    Happy trails.
  20. May 4, 2019 at 10:30 PM
    4x4yotaphan
    4x4yotaphan Well-Known Member
    SoCal
    SOLD: 2016 White TRD Sport DCSB 4x4
    Exterior: King suspension w/compression adjusters Icon billet UCAs Icon 3 leaf expansion pack Timbren rear bump stops w/U bolt flip kit Wheeler’s Offroad front superbumps BFG KO2 285/70/R17 on SCS Ray 10 17” wheels w/black wheel lock lug nuts TRD Pro grill TRD Pro taillights TRD Pro skid plate Demello Offroad front bumper Smittybilt XRC 9.5 comp winch w/Factor 55 fairlead and Flatlink E RCI LCA skids Beast Fab rock sliders 4 Extreme LED 4” pods Baja Design Squadron SAE LED amber fog lights Relentless Fab bedrail mount w/KC Flex dual amber chase lights AVS vent visors Interior: TRD Pro shift knob OEM instrument switch panel conversion (from 3 to 5 slots) Taco Garage DMM with Scosche Magicmount Upgraded Kicker sound system Husky X-act floor liners Performance: Airaid cold air intake system Pedal Commander w/Bluetooth
    Yes 2” with 275s is doable and depending on wheel offset, only minor plastic trimming no CMC. 285s more than likely CMC. I had 275s with Ray 10s (4.3” bs and -10mm offset) with slightly under 2.5” and had to trim about 1-2” of plastic on the bottom. Now running 285s on the same wheels with 2” of lift and need a CMC and remolding of plastic.
