What lift do I have?
Discussion in 'Suspension' started by SeNate, Apr 2, 2013.
  1. Apr 2, 2013 at 1:47 PM
    SeNate
    SeNate [OP] Well-Known Member
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    Satoshi Grill (HomerTaco), Ambiguous' headlights, refinished my frame with POR-15 after half a week of prep and rust removal
    I just read the suspension lift info w/ pics thread. So I think I have an in coil spacer in the front. I'll have to go crawl under my truck for the back. (pardon the massive rust, they heavily salt the roads here in SLC)
    Edit: I also do not know how high the lift is. I cannot remember what the original owner told me, I think he said 2". I am really looking for a proper 3" that doesn't jar me on every slight lump in the road.
    2nd Edit: Added new pictures to my last post (on page 2 for me)
  2. Apr 2, 2013 at 1:49 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    Spacers on the front, nothing on the rear. Looks like stock, TRD package shocks.
  3. Apr 2, 2013 at 1:50 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    You got a spacer in the front. Lifting it around 3 in or so. maybe 2.5". The rear doesn't seem to have anything in there. Post pics up of the whole truck to see how it is sitting. Stock upper control arms too. I bet your alignment isn't the greatest.
  4. Apr 2, 2013 at 1:53 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    The front looks like a 3 inch top spacer lift. The back looks like it could be a small block or nothing but hard to tell. I would get a new leaf pack or some add a leafs for the back. I would do 5100s and some new coil springs in the front. Goodluck. I bet the truck is riding rough right now.
  5. Apr 2, 2013 at 1:53 PM
    na8rboy
    na8rboy Well-Known Member
    The rear has a add-a-leaf. It's above your over load and second spring from top.
  6. Apr 2, 2013 at 1:54 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Where?
  7. Apr 2, 2013 at 1:56 PM
    ntilehman
    Seth
    Charlotte, NC
    x2
  8. Apr 2, 2013 at 1:56 PM
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    The rear is completely stock from the look of it.
  9. Apr 2, 2013 at 1:57 PM
    na8rboy
    You can see the short add-a-leaf, above overload.
    Look at the forth picture. That's not a TSB spring, that leaf is to short and no friction pad.
  10. Apr 2, 2013 at 1:58 PM
    SeNate
    Salt Lake City
    05 SR5 TRD 4x4 6spd
    Let me crawl under it and take a better photo. Yes, it rides very rough and the alignment keeps going off.
    I really would like to get a proper lift on this thing. BRB with pictures.
  11. Apr 2, 2013 at 2:00 PM
    ntilehman
    Seth
    Charlotte, NC
    Yea that might be one.
    5100 with eibachs in the front will give you a nicer ride. You will need to get some aftermarket control arms if you want to go over 2.5"
  12. Apr 2, 2013 at 2:04 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Looks like an AAL in the rear to me too.
  13. Apr 2, 2013 at 2:06 PM
    Monster Coma
    Corey
    Yeah I see it now. He has an SR5 which comes with 3 leafs (2 leafs and overload) from factory so 4 leafs would mean an AAL
  14. Apr 2, 2013 at 2:06 PM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    You'll need extended length coilovers and an aftermarket upper control arm to do it properly. Even then, 3" is at the limit of a setup like that.
  15. Apr 2, 2013 at 2:09 PM
    RadTaco914
    RadTaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    2017 DCSB TRD O/R "TURD GEN"
    ^X2 Spacer looks like it could be 3'' possibly...need to see how it sits level
  16. Apr 2, 2013 at 2:10 PM
    Monster Coma
    Corey
    OME doesnt use coilovers and is a good lift?
  17. Apr 2, 2013 at 2:12 PM
    JDMcQ
    The spring/shock assembly on Tacomas is a coilover. OME is just not an ADJUSTABLE coilover.
  18. Apr 2, 2013 at 2:13 PM
    GP3
    California
    4X4 TRD Off Road
    OME is another 3" option.
    I'm just not a fan of maxing out lift while decreasing droop travel. Hence my "at the limit" comment.
    Little to no droop travel = shitty ride. Many people think preload is the culprit to their rough riding 3" lifted truck.
  19. Apr 2, 2013 at 2:13 PM
    Mademan925
    Nick
    Discovery Bay, CA
    After looking at it twice I see the add a leaf. If you want a cheap solution that will ride better. Leave the back the same. Remove the spacers and add 5100s in the front at 1.75 or 2.5 and you wont need ucas or coils.
  20. Apr 2, 2013 at 2:17 PM
    Monster Coma
    Corey
    Right. My bad. I just meant you don't need to buy an extended travel coilover to get 3 inches
