What Lift Kit Should I Get?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NurseJenny, Nov 10, 2021.
  1. Nov 10, 2021 at 12:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice
    Never knew they offered a leaf pack, I know they offer an AAL.
    Edit: I looked, maybe they discontinued it? No leaf pack.
  2. Nov 10, 2021 at 12:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah see, you're in the 1st Gen section....recommending parts to a 1st Gen owner.
    treyus30 likes this.
  3. Nov 10, 2021 at 12:14 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
  4. Nov 10, 2021 at 12:15 PM
    Minny Taco
    Minnesota
    Meh, parts is parts.
  5. Nov 10, 2021 at 12:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :facepalm:
    If they don't fit, parts are instead paperweights.
    TacoBike and treyus30 like this.
  6. Nov 10, 2021 at 12:16 PM
    Minny Taco
    Minnesota
    If they don't fit, buy a 2nd gen.
    Superdave1.0 likes this.
  7. Nov 10, 2021 at 12:22 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  8. Nov 10, 2021 at 12:23 PM
    Minny Taco
    Minnesota
    Hey now! I had a 2001 double cab, but then I upgraded.
  9. Nov 10, 2021 at 12:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I thought only 3rd Genners acted like 3rd Genners :burp:
  10. Nov 10, 2021 at 12:26 PM
    Minny Taco
    Minnesota
    Come on Marine, I'm just messin' with you guys and avoiding work.
  11. Nov 10, 2021 at 12:28 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Shitty reason to downgrade IMO.
    Superdave1.0 and TacoBike like this.
  12. Nov 10, 2021 at 12:29 PM
    Minny Taco
    Minnesota
    It had 200k on it and the head gasket blew so it was time.
  13. Nov 10, 2021 at 12:39 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Buy the bolt on tons and 40 with triple bypass and dual spring rated coilover
  14. Nov 10, 2021 at 12:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Add the plug n play lockers; it's a drop-down add from most vendors nowadays.
  15. Nov 10, 2021 at 12:41 PM
    #35
    v5ensx
    AMEN
  16. Nov 10, 2021 at 1:29 PM
    #36
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    We found 30-40mph to work well but I almost flipped the truck trying to go 50mph. The rear end wanted to come around and the worst part was that the brakes didn't help to slow it down. We were lucky that there was no curve in the road.
    JasonLee[QUOTED] likes this.
  17. Nov 10, 2021 at 2:21 PM
    #37
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I recommend the Tundra brake upgrade and ensuring your LPSV/BPVV whatever the rear proportioning valve is adjusted correctly to ensure your brakes aren't applying way too heavy on the rear causing the slide out.
  18. Nov 10, 2021 at 3:39 PM
    #38
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    It's hard to adjust the LPSV when considering the fast up and downs of wash board roads plus extra carry weight in the back. Probably better off getting an aftermarket one to set and forget when the need arises.
  19. Nov 10, 2021 at 3:45 PM
    #39
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Those just clamp on to the axle housing, right?
    Or are you talking about the ones that mount with double sided foam tape?
  20. Nov 10, 2021 at 3:49 PM
    #40
    Kwikvette
    Fresno County
    4 run, 2 don't
    I mean if you wanna get fancy, sure.
    I just used the wire tie from a cheap loaf of bread.
