What lift kit to get?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaTSS, Mar 24, 2013.
  1. Apr 2, 2013 at 12:36 PM
    MaxQ
    MaxQ Active Member
    Southern California
    '13 PreRunner SR5 4x2 with exaust tip.
    Didn't really want that high of a lift. Just 2" to 3" max. What did that cost you? How long did the install take?
  2. Apr 2, 2013 at 1:21 PM
    xxnikkixx85
    xxnikkixx85 Well-Known Member
    Nikki
    Langley,B.C (Canada)
    Tacoma SR5 4x4
    PIAA FOG LIGHTS,Tinted Rear windows,Dunlop Fierce Mud Terrians,Blacked out badges,Blacked out taillights
    im having troubles myself on what lift to get i just want a 3inch lift would be perfect i dont carry heavy loads only thing i haul is my quad. I dont want the suspension stiff i just want the extra height for off roading adventures
  3. Apr 2, 2013 at 1:51 PM
    chris duby
    chris duby This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    Spindles and front brake lines - $520
    Blocks - $30
    Rear extended brake lines - $60
    Front adjustable Bilsteins - $199
    Rear extended Bilsteins for 3-4" lift - $199
    1.25" Spidertraxx wheel spacers - $99
    Total - $1107ish
    The install took me roughly 9 hours total. After I had one spindle installed the rest of the process was a breeze... except for the rear brake lines. Getting them threaded was not easy at all!
  4. Apr 7, 2013 at 5:11 PM
    Operator313
    Operator313 Well-Known Member
    Dave
    Iowa
    12 TSS Prerunner SR5
    Maxtrac Spindles 2 inch blocks on 1.5 AAl's (You jelly?) Kicker L78 Kicker 300.1 BLHM Color scratched grill
    I have the exact same truck as OP, almost. I am also looking for the same type of setup adding 33x12.5 tires. Keep us updated with what you end up with ComaTSS.
  5. Apr 7, 2013 at 9:38 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    ok. there are tons of ways to do this. I will try and explain. someone correct me if im mistaken
    a taller spindle will maintain factory ride at a taller height. factory suspension travel-limiting and geometry are maintained. ideal for pre-runners. you effectively lower the wheel mounting location in relation to all suspension components. one possible downside may be the added forces that could be translated to suspension components. you've put on a longer wrench so to speak in relation to upper and lower ball-joints. I would bet that you would have to hit something really effing hard to have this be a problem.
    a top-plate spacer lowers your spring/shock assembly (strut) in relation to its mounting point, raising the truck up. this renders the factory bump-stop (limits suspension up-travel) useless. your shock is your new limiting means and will be destroyed as it was not designed to do that. factory ride is maintained. people run these lifts around town.
    a coil spacer/ 5100 lift compresses the spring on the strut assembly. say for reference the Tacoma comes factory with 500lbs/in springs. it takes 500 lbs to compress them one inch, another 500 for another inch, and so on. so as the spring is compressed, it's effective spring rate is raised. say a factory truck is so designed that its own weight, exerted on its own springs, causes them to sag to a point halfway through its designed suspension travel limits. if we compress the spring on the strut assembly, prior to installing it on the truck, you effectively increase the spring rate, and the truck rides higher. a stiffer ride may be encountered because the coil is being compressed more than it was originally when you hit bumps.
    now you could buy taller coils. the only ones I've seen come with a tad higher spring rate than stock, but it is not very noticeable. for reference, a taller coil, with the same spring rate as factory, sags to the same lbs/in rating that the weight of the truck causes it to ride at. but since it is a taller coil, you have achieved that equality at a higher than stock height.
    top-plate spacers, coil spacers, and taller coils all alter the geometry that the truck was designed for under normal driving conditions. the general consensus is that 2" would be the max you would want to go to get factory alignment again. if you go higher, new upper control arms are needed that are designed to align at your new height.
    I bought taller coils, 5100 shocks to dampen them, and a progressive 3-leaf aal (also with 5100s) for my lift, and am very pleased. ome 884 coils if your wondering. if my truck was a prerunner, I would have bought a taller spindle
  6. Apr 9, 2013 at 10:49 AM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    '13 PreRunner TSS Edition V6 SR5
    Alright so now I am looking to either get a spindle lift or the 5100's with taller coils like you did. Are these prices about right? And please add in stuff other stuff that's going to have to be paid for.. such as extended brake lines and stuff. Please recommend better brands if needed.
    Total Chaos 3.5" Lift Spindle (brand recommended in another thread)
    $1349
    Bilstein 5100 Adjustable shocks
    $500ish
    Plus OME 884 Coils
    $160
    Equals $660
  7. Apr 9, 2013 at 12:18 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Your rear is going to be dragging.
    +5.5ish" up front & +0 rear.
  8. Apr 10, 2013 at 10:30 AM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    Does this sound a little better?
    $1349
    plus OME Dakar leaf springs
    $400
    Equals $1749
    $350
    Plus OME 884 Coils
    $160
    Plus OME Dakar leaf springs
    $400
    Equals $910
  9. Apr 10, 2013 at 10:40 AM
    ComaTSS
    ComaTSS [OP] Member
    Evan
    Arkansas
    I guess this would be easier if you're going the bilstein/coils route. 3" lift kit with Bilstein 5100 Height Adj. Coilovers
    $900
  10. Apr 11, 2013 at 6:57 PM
    92dlxman
    Kevin
    Visalia, CA
    looks like a cool, strait-forward lift, taller coils+preload, but I think you'll need upper control arms to align it.
    2" is about as high as you can go with factory alignment specs.
  11. May 20, 2013 at 7:01 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    If the OP were to go the 5100's route on all 4 corners, should he get the extended 5100's for the rear or the 5125's for the rear. I ask this cuz I'm in the same boat?
    And that's with new OME/ Dakar 2.25" spring pack in the rear ASWELL.
