What lift would you guys recommend
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trailhunter, Dec 22, 2013.
  1. Dec 22, 2013 at 9:16 AM
    Trailhunter
    Trailhunter [OP] Member
    Grey wire
    I finally bought a 2001 4dr taco and I've had it all of 24hrs ....... Grey wire mod done in the first hour CHECK! Now I'm doin research for the best all around lift. I won't be rock crawling but I will be in the bush every weekend for the rest of its life. I plan on running 33's-34's. I don't want cheap junk that's gonna give me greeff so keep that in mind.
    Now that being said what lift are you running?
    What problems are inherent with certain lifts?
    What would you different now after if you had the chance?
    I'm so excited about this build I'm gonna loose sleep :D
  2. Dec 22, 2013 at 9:24 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    What's ur price range?
  3. Dec 22, 2013 at 9:26 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    Edit: Ooops... nm
  4. Dec 22, 2013 at 9:40 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Congratulations on the truck! I had a 2003 DC and miss it almost every day.
    I installed a complete OME setup with the Dakar leaf packs. Simple, proven and reliable. It also worked great in any situation I put it in.
    As far as tires go, the worst thing I ever did to my truck was install the 285/75/16s. There was a tone of rubbing issues and just turned in to a PITA. If I had to do it again and was dead set on 33s, I would go with 255/85/16. Same diameter just more narrow, thus helping to eliminate some of the rubbing.
    Good luck and have fun!
  5. Dec 22, 2013 at 10:05 AM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    I fit 285 75 16 s no rubbing . I have Billie 5100s up front with eibach springs. Im right at 3 inches in the front. Rear I have 5125 extended length with Dakar leaf packs and 1.5inch shackles. Get about 3.5 inches in the rear. Running 285/75/16 mud terrains with no rubbing even when flexed. Did some minor bashing on the pinch welds in the from wheel area...
  6. Dec 22, 2013 at 11:19 AM
    kn38ms
    kn38ms Well-Known Member
    NW, FL
    Pinion angles okay?
    Input shaft's lengthened?
    Your set up is relative to my interests...:D
  7. Dec 22, 2013 at 12:02 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Had some troubles at the start but it was all fixed with a diff drop
    and the boot slide mod. Also needed the extended rear brake line.
  8. Dec 22, 2013 at 12:33 PM
    Trailhunter
    Grey wire
    Price range isn't much an issue ...... Reliable and quality is my main consern
  9. Dec 22, 2013 at 12:39 PM
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    If it isn't a issue I'd go all out:D
  10. Dec 22, 2013 at 12:42 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Dakar leaf springs with U bolt flip kit and then custom mount your rear shocks
    front go extended King, Icon or fox with an aftermarket UCA. This is a nice mid travel set up.
  11. Dec 22, 2013 at 2:00 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Icons FTW...
  12. Dec 22, 2013 at 2:33 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Without cost being a concern, I would probably go either OME Dakar or custom Alcan leaf packs with Icon remote reservoir rear shocks, then Icon extended travel coilovers with aftermarket upper control arms.
  13. Dec 22, 2013 at 3:43 PM
    JDMcQ
    All trucks are different. I had to cut the pinch weld off completely and reshape the firewall to get rig of the rubbing. I had to move the firewall so much, the kick panel inside needed trimming.
  14. Dec 22, 2013 at 4:04 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    True where you running stock rims?
  15. Dec 22, 2013 at 4:50 PM
    JDMcQ
    I was not. I do not remember the specs on the wheels, but I did end up having to run 3/4" wheel spacers to get the tires off the frame.
  16. Dec 22, 2013 at 5:25 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    X2 if money isn't a problem go all out :D
  17. Dec 24, 2013 at 8:23 PM
    Trailhunter
    Grey wire
    Well I think I made my mind up with a toytec 3 inch lift. Now there is an option to up grade from med 600lb springs to 650lb ....... Is this 650 gonna ride rougher ? I do plan on putting a fairly Heavy bumper and winch so well I be better off with the 650?
  18. Dec 24, 2013 at 8:36 PM
    Dcpsychobilly
    Aurora Colorado
    04 dbl cab Taco
    Hmm being adjustable you can just crank up a bit for the extra weight, 650 might be too much but I'm not 100%sure. I have 600coils and about 300 extra weight and ride good also have 285s
  19. Dec 25, 2013 at 11:27 AM
    HBtaco02
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    I have extended Kings with 700lbs springs. Rides a little rough on road but off road where it counts it is awesome. . I have bumper winch sliders and will be adding skids soon...
  20. Dec 25, 2013 at 11:29 AM
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    dankers in the rear and 5100 with eibachs up front IMO
