What Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aztacotrd, Feb 20, 2011.
  1. Feb 20, 2011 at 11:04 AM
    Aztacotrd
    Aztacotrd [OP] Well-Known Member
    Austin
    Az
    O8' V6 Prerunner Accesscab
    I plan on ordering my lift kit today and I've been toying between the OME lift kit from toytec and the ultimate lift kit with Radflow coilovers since it's on sale.
    What would you suggest? Is the extra $450 for the ultimate lift kit worth it?
  2. Feb 20, 2011 at 7:04 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    A body lift and some bigger tires will give you the same amount of lift.
  3. Feb 20, 2011 at 7:34 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    I think you have to add a top plate spacer to the OME kit to get a full 3"
  4. Feb 20, 2011 at 9:42 PM
    Malamute
    Malamute Active Member
    Dan
    CO
    I was going to go with the Icons that were on sale but after much debate and research I've decided that the OME fits my needs fine and I can get it with Dakars in the rear for right at $1k. Depends on what your plans are but I think you'll be happy either way. I don't need the adjust-ability so I'm going OME.
  5. Feb 21, 2011 at 8:49 AM
    Aztacotrd
    Austin
    Az
    Now I'm thinking either the pro comp kit or the OME kit. I don't really offroad so really i'm just looking for on road ride quality and the lower price of the procomp appeals to me. Is there anything else I will need with my kit? Like extended break lines etc?
  6. Feb 21, 2011 at 1:07 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Go OME. Or bilstein 5100's on all four corners. With eibach springs up front. Set your adjustable 5100's up front to .85. You'll end up around 2.5 inches up front. Then throw on a 2 inch AAL.
    Very good ride quality for the daily driver.
  7. Feb 21, 2011 at 1:10 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I have 5100's on all 4 corners and the ride is better than stock but still rough. If i won the lottery, or had more money, i'd go with the OME kit-cheap and reliable
  8. Feb 21, 2011 at 8:43 PM
    Blacktacoma23
    Denver/Phoenix
    X2 for the Pro Comp
  9. Feb 21, 2011 at 8:47 PM
    blacktaco21
    blacktaco21 Crunchy Taco
    AR
    05 TRD Sport DC 6" 325/65R18
    Fabtech 6" Baja Tire Carrier Limo Tint 4.88 Gears Detroit Locker Rear ARB Locker up front Train Horns Pioneer DVD Double Din JL Audio 12w3v3 325/65R18 Baja MTZs 18x10 Classic Locks Powder Coated Flat Black
    If you want ride quality stay stock.. Suspension lift = stiffer ride due to AAL, block, spacer, stiffer springs, or however you achieve lift. Soft rides are for cars.
  10. Feb 21, 2011 at 9:01 PM
    Blacktacoma23
    Denver/Phoenix
    Who makes some cheap UCA's?
  11. Feb 21, 2011 at 9:05 PM
    blacktaco21
    AR
    depends on your definition of cheap.. you get what you pay for
  12. Feb 21, 2011 at 9:07 PM
    Blacktacoma23
    Denver/Phoenix
    Alright, some UCA's that are an improvement over stock?
  13. Feb 21, 2011 at 9:14 PM
    blacktaco21
    AR
    and there's Total Chaos. I'm sure there's others out there but some are long travel which are different than stock. Most people run Total Chaos..
  14. Feb 22, 2011 at 1:48 PM
    drjohnson36
    drjohnson36 Well-Known Member
    09 Pre-Runner SR5 DC
    I have an OME kit with Light Racing UCAs. The UCAs are great for street use, but if you plan on offroading, go Total Chaos, you get what you pay for, and they're only about $200 more.
  15. Feb 23, 2011 at 6:38 AM
    Aztacotrd
    Austin
    Az
    So last night i drove my buddy's truck with the procomp lift and it was exactally what I wanted. Is there anything extra i'll need to complete my lift? Other than UCAs. Also, what type of specialty tools will be needed to install the lift? i have the essentials like sockets, jackstands, jack, etc.
  16. Feb 23, 2011 at 9:15 AM
    Aztacotrd
    Austin
    Az
    Awesome it says that it includes all of that. One last question.... It came with an aal but I have the leaf tsb so it won't be level. Can I take off my 4th leaf from the tsb and then put on their aal for the right amount of lift?
  17. Feb 23, 2011 at 9:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Only on double cab 4x4's
  18. Feb 23, 2011 at 9:19 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Sometimes , yes ?
  19. Feb 23, 2011 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 885's on prerunners gives 3" lift after they settle.
  20. Feb 23, 2011 at 9:24 AM
    OZ-T
    Peter North
    British Columbia
    You thinking I'll get 2 1/2" on my truck?
