what lights to get
Discussion in 'Lighting' started by dylanjohnson14, Dec 10, 2012.
  1. Dec 10, 2012 at 8:06 PM
    dylanjohnson14
    dylanjohnson14 [OP] Member
    Dylan
    07 toyota tacoma double cab PreRunner
    so i have a 07 tacoma 4 door standard, and i want to replace my lights with bright ones that will give off that bright color like HID but not have to put in a kit. please help me and tell me what the right lights are called that can get me that blue kind of HID COLOR
  2. Dec 11, 2012 at 12:12 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Blue is less bright than white. The brightest light is 4300ºK white to 5000ºK white (with a slight blue hint).
    As you go to higher color temperature, the light gets bluer and dimmer.
    As you go to a lower color temperature, the light gets yellower (3000ºK) such as our halogen headlights.
    HIDs put out more light and use less power... 35 watts, for example will put out light better than 130 watt halogen bulbs. 55 watt HIDs are available and can make the blue 6000ºK-8000ºK HIDs brighter, but still not as much light as 5000º.
    If you want just a brighter halogen bulb and not convert to HID/xenon bulb which needs a ballast and starter 'kit', then check out your local auto parts stores selection of bright halogen bulbs.
  3. Dec 11, 2012 at 1:10 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Blue lights are gay. I'll agree with DavidK here.
