What maintenance required at 80000-miles
Discussion in '4 Cylinder' started by Mantis808, Aug 19, 2012.
  1. Aug 19, 2012 at 10:33 PM
    Mantis808
    Mantis808 [OP] New Member
    Honolulu
    07 Tacoma Standard 4WD
    Aloha,
    I have a 2007 Tacoma (4WD) 4Cylinder Standard trans..what maintenance should I perform at 80,000+ miles? I am the second owner and the truck runs great but no manual came with truck. Any timing chain/belt issues, spark plugs, etc? I do take it off road, camping and rambling. Appreciate it.
  2. Aug 19, 2012 at 11:04 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    at 80K, you're looking at new spark plugs soon, Coolant flush, tranny fluid, air filter, fuel filter. Also may want to change differential fluid and grease your zerks. timing chain should be good for the lifetime of your engine.Welcome! :wave:
  3. Aug 19, 2012 at 11:15 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    This covers it and op you gunna take it to the dealer or DIY
  4. Aug 20, 2012 at 3:53 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If you have no documentation about the service done by the previous owner of your truck, you could do the 90/100k stuff early if it will make you feel better and if you have the spare time and money now. There's lots of info online about the recommended maintenance intervals. Check this site:
    http://smg.toyotapartsandservice.com/guides.php
    I recall several threads saying there is no fuel filter in the 2nd gen Tacomas, just a screen around the pickup in the tank. Air filter replacement is every 30k unless you have an aftermarket filter. Also you might want to inspect the serpentine belt and brake pads/shoes. Transmission, coolant and spark plug service is at 100k. That's all I can remember without looking up this stuff. Hope this helps.
  5. Sep 1, 2012 at 12:51 AM
    Mantis808
    Honolulu
    Thanks for the advice!! I will probably go to a local mechanic that I like in Kalihi. The dealership is usually a bit more pricey. Cheers
  6. Feb 28, 2013 at 2:19 PM
    poteran
    poteran Active Member
    david
    LOS ANGELES
    SR5
    is there as thread on here that shows us how to DIY coolant, tranny and diff on 2nd gen 4 cyl? im am approaching 100k. thanks
  7. Feb 28, 2013 at 5:24 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    I may over maintain my truck but every 20,000 miles i do the 30k maintenance intervals, seeing i get all my parts at cost plus 10% it's pretty cheap. If something is loose or out of spec I will replace that part. I do go by the saying if it aint broke don't fix it.
