What maintenance would you recommend I have done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Broogie, Jun 16, 2019.
  1. Jun 16, 2019 at 7:17 PM
    Broogie
    Broogie [OP] Member
    Mark
    Vancouver, BC
    2011 Tacoma DCSB TRD Sport 6MT
    Whats up taco world? First time poster here. I got my 2nd gen taco at about 50,000km a few years ago and now we're at 80k present day. I hope I don't get flak for this but since purchasing the only things I've had to do were; fix the A/C, get new tires and perform regular engine oil changes. I'm not the kindest driver on my taco but I figure its a tacoma what am I really going to do to break it haha. Ive only off-roaded a handful of times and nothing to gnarly. The bad boy isn't sounding as healthy as he used to so I thought I'd turn to taco world for tips on what you guys do for regular maintenance and what you would recomend for preventative maintenance for someone who has done little to none of it, better safe than sorry! I appreciate anyones input or tips and my apologies if I selected the wrong subforum for posting!
  2. Jun 16, 2019 at 7:26 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Transmission fluid drain/fill or line-exchange. If you do a lot of slow speed crawling, then this is a must do because that builds up tranny heat, and heat degrades fluids.
  3. Jun 16, 2019 at 7:30 PM
    Shellshock
    Iowa
    Do a drain and fill on the trans. Change the diff fluid. Keep on driving
    MrKatanga likes this.
  4. Jun 16, 2019 at 8:07 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I’d start by looking in the maintenance manual and determining which services are past due and address those.
    And welcome to the forum.
    Blockhead and MrKatanga like this.
  5. Jun 17, 2019 at 1:54 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If 4x4 - then change both diffs and xfer case fluids. Have shop do full trans flush/replace or if no heavy use book says at 100k (had mine done then and shifted better) but now with all my towing I do every 50k. Coolant flush and refill and drain/flush at the 2 engine block drains one each side and use the pink Toyota coolant. Of course you must have put in an air filter (every 25k miles or when dirty) and a cabin air filter behind glove box. Check the serpentine belt for wear and check at least the front brake pads and rotors. If the engine is running rough clean the throttle body and possible spark plugs but did mine at 115k and they were still good.
    (Add your Tacoma model and year to your profile so then we know type)
  6. Jun 17, 2019 at 3:30 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    It sounds like the issues may be greater than just fluid changes if the OP is stating the truck sounds unhealthy. I'm beginning to question the oil change intervals the truck has been receiving. OP, please describe why the truck doesn't sound right? Any idling or driving issues? Noises?
  7. Jun 17, 2019 at 4:07 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Exactly. You need to be more specific on your Tacoma not sounding healthy. That would be a good place to start.
  8. Jun 17, 2019 at 4:10 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip: Change all fluids for sure
