What makes a truck taller?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808Bradah, Nov 3, 2012.
  1. Nov 4, 2012 at 9:10 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    the overall height of the wheel and tire combo will give you more ground clearance. It is more based on the tires since you can put several different sized tires on say a 16" wheel.
    Look at it this way OP, you know where the axle meets the wheel (you know, at the center of it) the distance from the center (hub cap) to the ground is how high your hub cap is. So if you have 30" tires, your hubcap sits 15" off the ground. IF you had 40" tires the center of the hubcap would measure in at 20" off the ground.
    (for those who already get this I understand that the differentials and crossmember sit lower than the center of the wheel, I just want to give him a simple visual)
    Taller tire means more ground clearance at the axle, however a "suspension lift" will raise the body of the vehicle up higher and yet provide no more ground clearance. It is simply done to try and fit taller tires in the wheel well
  2. Nov 4, 2012 at 9:11 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    ^ that was uncalled for ^ :mad:
  3. Nov 4, 2012 at 9:12 AM
    mtwil9
    mtwil9 Well-Known Member
    Birmingham
    12 TRD Off Road 4x4
    Bilstein 5100 F&R Eibach at .85 with top plate spacer, 1.5 AAL,LR UCA's Tinted Windows, Weathertech Floormats, Ultra Gauge, 20" light bar behind grill
    ^ exactly what I was thinking
  4. Nov 4, 2012 at 9:14 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I agree, there are stupid people and then there are people who aren't informed yet. STUPID people are douchebags who are incapable of considerate thought. Uninformed persons may very well be fully capable of grasping a subject and just haven't ever researched it yet. Give the kid a chance to grow up and learn some, either answer the question or move along. Only STUPID people would waste their time trolling to be a jerk. But what do I know, I'm not a master mech for Toyota so I know less than someone out there, therefore I must be stupid. :rolleyes:
  5. Nov 4, 2012 at 9:21 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Consider the source a self proclamed Douchebag
    4x4jeep[​IMG]
    Hatters gonna Hate So FUCK em
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Gender: Male
  6. Nov 4, 2012 at 9:23 AM
    MLJak
    MLJak Well-Known Member
    Anchroage
    2011 V6 Access Cab Base
    And there's intelligent, educated people who are new to Tacoma trucks and wonder the same thing as those who ask questions. I read this article, learned the process a bit, and now feel better informed when I go shopping for new tires.
    Good question OP.
  7. Nov 4, 2012 at 9:28 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    There is a balance to it. By all means the same old questions to get tiring, but if someone is new to the whole shebang just direct them and let them know that there are search options that may help in the process of their research.
    OP, sorry for the sidetrack haha have we answered your question thoroughly?
