What makes an expensive shock expensive?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Oct 7, 2022.
  1. Oct 7, 2022 at 6:47 PM
    5efvz
    5efvz [OP] Well-Known Member
    Looking to replace the rear shocks. They're black and rusty. I'm assuming they're original shocks that came from the factory. I don't see any leaks.
    Shopping for new rear shocks from RockAuto, what exactly sets the $20 shock apart from $120 shock? Is it different oil used inside or stiffer springs or beefier housing?
    As someone that will not be doing any rock crawling. But, mostly paved roads and maybe gravel and dirt roads 5% of the time, do I really need to go with expensive ones?
  2. Oct 7, 2022 at 6:56 PM
    Firn
    Firn Well-Known Member
    White OR
    What makes a Briggs and Stratton different from a Chevy LS?
    What makes a quality laptop different from the $250 one from Costco.
    Better shocks will use higher quality components, and more of them, tighter machining tolerances, larger components,more oil,better oil, smoother and longer lasting seals, etc. They will give a better ride while also improving handling.
    I just installed Bilstein 6112s up front. They ride much firmer, yet at the same time are far less stiff. Handling is tighter but road imperfections float by. There is a speed hump leaving my work, previously the truck fet uncontrolled hitting it at anything over 15mph, now I can do 20 and you hardly notice driving over it (no, seriously)
    Wulf, 5efvz[QUOTED][OP] and Key-Rei like this.
  3. Oct 7, 2022 at 7:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    $120 is cheap...
  4. Oct 7, 2022 at 7:09 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You don't want a 20 dollar shock. It would prob. be defective right out of the box.
    Like the worst factory in China making everything from shocks to shower rods and using the same steels for both.
  5. Oct 7, 2022 at 7:54 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I would choose something in the middle....
    I went with KYB......again like the akebono pads ...
    ......made by Japanese for Japanese vehicles......
    5efvz[OP] likes this.
  6. Oct 7, 2022 at 7:56 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yeah I paid about 10x that for just my front shocks.
    :bananadead:
    5efvz[OP] and Speedytech7 like this.
  7. Oct 7, 2022 at 7:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    $380 a piece for rears and damn near $700 a piece for fronts .. RIP in peace
    5efvz[OP] and Key-Rei[QUOTED] like this.
  8. Oct 7, 2022 at 8:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hmm...Fox 2.5 front/2.0 rears on the Tacoma, King 2.5 front/2.5 rears on the 4Runner, and Icon 2.0 front/2.0 rear on the Land Cruiser...
    Not really wanting to total it all up
    Just a bit shy of $5k just for shocks and that doesn't include leaf pack or coils for said vehicles:bananadead:
  9. Oct 7, 2022 at 8:04 PM
    Speedytech7
    Did it include lube? Or at least a well hocked glob of spit?
  10. Oct 7, 2022 at 8:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The reach around is coming...or so I was told :anonymous:
  11. Oct 7, 2022 at 8:11 PM
    Speedytech7
    5efvz[OP] and Kwikvette[QUOTED] like this.
  12. Oct 7, 2022 at 8:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No but really, I know the number is rather generic
    I got the Fox 2.5 and 2.0 in a group buy here in the forum; regularly $1700 for both front and rear I saved quite a bit there
    The King 2.5 front and rear I got with a military discount of 10% otherwise regular price would've been about $2100
    And the Icon 2.0 front and rear I got from another vendor with a military discount, can't remember if it was 5 or 10% but regularly would've been $760
    Much easier (and cheaper) buying coils (4Runner or Land Cruiser) than buying a leaf pack (Tacoma)
  13. Oct 7, 2022 at 9:17 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    :rofl:
    But I would know...
    Kwikvette[QUOTED] and 5efvz[OP] like this.
  14. Oct 7, 2022 at 9:30 PM
    O'Silver_Taco
    MD
    Well if was gonna spend 5K on shocks.....I wouldnt stop halfway there....
    or in this case 17% of way there.....might as well get rid of the frame and increase it to 200hp.....
    MGMDesertTaco and 5efvz[OP] like this.
  15. Oct 7, 2022 at 9:37 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    To answer your question - No. You don’t need expensive shocks, just decent ones. Since you have been running rusty old shocks any decent quality shock will suit your need. KYB’s, bilstein 4600, Bilstein 5100 or inexpensive take-offs from any nearly-new Tacoma on Craigslist.
    Decent shocks have better seals and will last longer. High performance shocks have bigger pistons, bigger bodies, more/better oil, handle high heat dissipation and can have extended shock travel options. You don’t need that based on your use description.
    Agree you should skip the cheap made-in-China shocks.
    Firn and 5efvz[QUOTED][OP] like this.
  16. Oct 7, 2022 at 9:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just about every single person I've met on a trail that drives one of these is a turd of a human being:burp:
    vern650, MGMDesertTaco and 5efvz[OP] like this.
  17. Oct 7, 2022 at 9:41 PM
    5efvz
    Is Rancho brand decent?
  18. Oct 7, 2022 at 9:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Garbage.
    Just get yourself Bilstein 4600's.
    Proven and affordable.
  19. Oct 7, 2022 at 9:42 PM
    Speedytech7
    And those things are fucking lame to drive, you're exposed to everything and no matter ho much you spend on the suspension they're rattly and uncomfortable. I'd rather have the AC on in my truck if I'm gonna bomb trails all day, plus then I have tires big enough to climb obstacles and terrain rather than just ruin it like most SxS guys do
    Kwikvette[QUOTED] likes this.
  20. Oct 7, 2022 at 9:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I can't imagine getting my nose or mouth stuffed with dirt, and god forbid the sun is out so you're left baking too.
    I do love my AC that's for sure.
