What makes my Taco grande?
Discussion in 'Suspension' started by belone12, Sep 26, 2012.
  1. Sep 26, 2012 at 9:33 AM
    belone12
    belone12 [OP] Well-Known Member
    Brian
    Long Island, NY
    06 Tacoma Double Cab 6spd TRD OR
    Bilstein 5100s, AAL, heated leather seats, Thule Rack, tow package, anytime foglight, Fold-a-cover
    Like a broken record, I just bought this Taco from a wholesaler that could give me limited information, so I'm just sorting it as i go. It definitely rides higher, but the suspension looks stock. So i have to imagine it's some other "lifting" method for tire clearance. This pics aren't the best, but can anyone help me understand what i have under there? I'm hoping it's not as bad as looking under a skirt in a Bangkok night club...
  2. Sep 26, 2012 at 3:19 PM
    belone12
    Brian
    Long Island, NY
    I will take better pictures when I have a chance if that helps...
  3. Sep 26, 2012 at 3:23 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Dear lord, I hope it's not a body lift. But it looks like 2" lift...tire size? Looks like there are no blocks or AAL, and no TSB in the rear. Take pics of the top of the shock, and under the carpet if you can anywhere.
    Those rear shocks don't look OEM to me.
  4. Sep 26, 2012 at 8:03 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Looks stock to me... Rear shocks are not OEM. If there was body lift there would be gaps between bumpers and fenders, no gaps that I can see...
    That truck was rear ended also, see how the rear bumper is tilted?
    Maybe just a 265/75/16 tire which runs little larger for its size...
  5. Sep 26, 2012 at 10:47 PM
    belone12
    Brian
    Long Island, NY
    Thanks guys. Yeah as per the carfax it was in 2 accidents. The front bumpers are a bit banged up/ detached as well, no airbag deployment though. I will get better pics next time I am at my bothers (where I keep it). I really appreciate the help as I am new to this and want to learn, but I want to have a solid rig. I'm looking at it as a long term project, just want to do it right.
    Thanks again
  6. Sep 26, 2012 at 10:54 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    What tires are on your truck??
  7. Sep 27, 2012 at 12:42 AM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    10 TRD off road doublecab 4x4 silver
    plenty
    the side profile you can see a aluminum spacer on top of the strut
    and I see an AAL
  8. Oct 8, 2012 at 8:22 AM
    belone12
    Brian
    Long Island, NY
    I had some truck time this weekend. The tires are Mudstar Radial M/T's LT285/75R16. If I am going to be driving this around in the winter in the Northeast, I should probably be switching to A/T's right? I will post the pics of the shocks next.
  9. Oct 8, 2012 at 8:25 AM
    belone12
    Brian
    Long Island, NY
    This is what was reflecting in that picture:
    Tuff Country in the Rear
    Hope these help with nailing down what is under there...Appreciate the help and input from everyone!!
  10. Oct 8, 2012 at 8:30 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    definitely add a leaf and a strut spacer
  11. Oct 8, 2012 at 8:51 AM
    belone12
    Brian
    Long Island, NY
    Is that good/bad/indifferent?
  12. Oct 8, 2012 at 9:30 AM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    add a leaf is a good rear lift option, im not a huge fan of large strut spacers, but they arent that bad. id upgrade the front if you plan on doing alot of off roading, otherwise the setup you have is fine
  13. Oct 8, 2012 at 10:39 AM
    belone12
    Brian
    Long Island, NY
    Sounds good, thanks much for the input! I am only doing some trails for now, nothing too technical. I will keep it as-is, and use the funds to get a good set of A/T's before the snow falls.
    Thanks!
  14. Oct 8, 2012 at 11:43 AM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    Sounds like a plan! Good luck with it. And I see you just joined last month, so welcome to TW!
  15. Oct 8, 2012 at 11:53 AM
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    wonder if there are wheel spacers as well to fit 285's with oem wheels.
  16. Oct 8, 2012 at 11:53 AM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    Probably are
  17. Oct 8, 2012 at 12:04 PM
    cgs2k2
    cgs2k2 Ohio Member
    Nadeem
    2006 AC 4x4 OR
    Looks really nice! AAL is good, and the new rear shocks are good for the added travel with the AAL. Front spacers are usually frowned upon by most on the site, but a lot of people run them with no problems - especially if you are mostly on road and light trails. Just don't try to jump your truck or hit any obstacle too fast.
    As far as winter and tires - AT is definitely better. MTs are usually not very good in the snow.
    Good luck!
  18. Oct 8, 2012 at 12:23 PM
    belone12
    Brian
    Long Island, NY
    Thanks for the welcome tacoftw
    Thanks dude, tires are my next focus. I already got duped on Friday by a guy that sold me a tonneau cover for a Gen 1 truck that he swore and still swears was on his 05 and had it listed as 2005-2011 tonneau. I brought it home and it is too small. Extang confirmed it wouldn't fit anything older than 2004. Anyway, just griping b/c I appreciate all the help this forum has given me the past month despite a-holes out there just looking to make a buck. If anyone knows someone that needs one, i postd it. I love this truck, long overdue purchase!
