What makes synthetic motor oil better?
Discussion in 'Technical Chat' started by rnish, Jul 8, 2016.
  1. Jul 8, 2016 at 6:43 PM
    rnish
    rnish [OP] Well-Known Member
    Tacoma 2nd gen
  2. Jul 9, 2016 at 5:06 PM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Go to www.AMSOIL.com , check out the Signature Series 100% Full Synthetic Oil Lines !
  3. Jul 11, 2016 at 11:29 AM
    tgear.shead
    tgear.shead Well-Known Member
    Well... for one, they are comparing a 15w to a 5w, which is not a valid comparison. Second, they aren't stating just HOW used the used 15W happens to be. I suspect that it has been run FAR beyond its service interval, like 10 times as far or more.
    So their video is dramatic, but invalid.
    And actually, there is one thing they talk about in that video that is completely wrong... they suggest that the older the oil gets, the WORSE it flows when cold. This if factually incorrect. In fact, the older the oil gets, the THINNER it becomes at HIGH temperature. Multi-viscosity oils are multi-viscosity because of polymers added to them that coil up at low temperatures, and stretch out at high temperatures. They stretch out as the oil warms up in order to maintain a high viscosity (thicker). As the oil ages, the polymer breaks down, and the high temperature viscosity ends up lower than it would otherwise be, while leaving the low temperature viscosity more or less the same.
    So that video is actually comparing 15w40-based SLUDGE with clean 15w40 with slightly used 5w40 with clean 5w40.
  4. Jul 15, 2016 at 11:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    synthetic doesnt breakdown or lose viscosity as quick as regular oil or thats what I was told.
  5. Aug 7, 2016 at 12:48 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    I agree good sir.
    It maintains a more consistent viscosity at a wider temperature range. Both negate and positive temperatures.
  6. Aug 7, 2016 at 2:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It costs more so therefore it just has to be better !!!
    Thing is it will pick up particles of metal so it still needs to be changed sure it might take longer to break down .
    Although it is getting more research all the time
    It is much better then when it first hit the public years ago
    Myself I still have yet to jump on the band wagon
  7. Aug 7, 2016 at 4:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    'News' sites like that should be ignored. When you open it up, it's filled with ads and dramatic headlines for other 'stories' it's nothing to clickbait.
    I'll take my oil explanations from a tribologist.
  8. Oct 27, 2016 at 5:33 PM
    jmdwifi
    jmdwifi My Inferno
    Fredericksburg, Virginia
    See profile
    Man made oil still has fine dirt in it. It comes from the earth. There is no dirt in synthetic oil. I read it on the internet, sooooooo
  9. Oct 28, 2016 at 8:10 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Conventional oil the molecules are square under a microscope. Synthetic the molecules are 100% round. Thats why synthetic causes less wear and tear
  10. Oct 29, 2016 at 9:16 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Huh?
    Conventional motor oil has molecularly that's differing in it's circumferences. Synthetic is uniform in that aspect... At least that's what the interstates told me. :rasta:
  11. Oct 29, 2016 at 11:04 PM
    757yotas
    Virginia
    2007 TRD Sport
    Thats the easist way to explain it to people, synthetic has perfected formed molecules while as conventional does not. That is also why synthetic oil can make leaks appear when conventional hides them due to molecular shape.
  12. Nov 1, 2016 at 7:53 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I dismissed it as rubbish as soon as I saw "msn.com"
