What manifold gasket with turbo manifold (5vz)
Discussion in 'Performance and Tuning' started by vasinvictor, Jul 30, 2019.
  1. Jul 30, 2019 at 12:51 PM
    vasinvictor
    vasinvictor [OP] Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I've been using CX manifolds for 2+ years and I used the gasket they supplied. It's a thicker type gasket. Last time I went to the track I came home with an exhaust manifold leak. What does everybody use? Stock gaskets or something better?
  2. Aug 1, 2019 at 9:02 AM
    vasinvictor
    Drew
    Arkansas
    '01 DCSB racetruck
    I guess I should have posted this in the Turbo BS thread?
  3. Aug 1, 2019 at 9:35 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
  4. Aug 2, 2019 at 7:59 AM
    vasinvictor
    Drew
    Arkansas
    '01 DCSB racetruck
    Thank you. I thought thicker gasket would take out some of the warpage if any develops, but I keep seeing these copper gaskets being used.
  5. Aug 2, 2019 at 8:37 AM
    Jon64l
    Jon
    Copper gaskets are softer than steel gaskets and can form a better seal. You should have your manifolds resurfaced before you put them back on, then torque them evenly the same way a cylinder head is torqued. This should keep everything flat and true for along time.
    vasinvictor[OP] likes this.
  6. Aug 2, 2019 at 11:13 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I'm using the OEM MLS gaskets with good luck so far.
  7. Aug 5, 2019 at 1:53 PM
    vasinvictor
    Drew
    Arkansas
    '01 DCSB racetruck
    I have a set of OEMs off a used motor I'll probably just throw those on. I wish I hadn't used that gasket that came with the kit... I knew better.
    Brice likes this.
