What method do you use to tighten the axle nut?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, May 20, 2020.
  1. Loved in 4WD
    14.3%
  2. Pry bar in the lug studs
    21.4%
  3. Screwdriver in the rotor against the caliper
    25.0%
  4. Other
    28.6%
  5. Some one pressing the brakes
    10.7%
  1. May 20, 2020 at 3:40 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve seen it done numerous ways.
    Lock in 4WD, place the opposite tire on ground.
    Bar between the lug studs.
    Screw drive in the rotor veins against the caliper.
    I usually go with a pry bar in the lug studs myself.
    How about you?
    Biscuits likes this.
  2. May 20, 2020 at 3:42 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    screwdriver.... or I have the Mrs. come out and hit the brakes
    Mully likes this.
  3. May 20, 2020 at 3:45 PM
    3pooches
    3pooches Well-Known Member
    VA & WV
    15 tacoma dcsb Sc Linked, 2014 reg cab locked
    Impact gun :notsure:
    Gunshot-6A, wrmathis, 3JOH22A and 8 others like this.
  4. May 20, 2020 at 3:47 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I run that bitch in with an impact gun. 30 ugga duggas and it’s good. Gets a castle nut and a cotter pin so it’s not going anywhere.
    Gunshot-6A, SliMbo4.0, Crom and 7 others like this.
  5. May 20, 2020 at 4:04 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I do it on the ground. Usually with better half on the brake. Dat fockers tight...
    Crom likes this.
  6. May 20, 2020 at 4:06 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    I would think "Loved in 4WD" would be the winner.
    SR-71A, Crom, Cooldood and 1 other person like this.
  7. May 20, 2020 at 4:11 PM
    TnShooter
    Deogee
    STOCK
    Lol. That is exactly the way I do it. Except I thread regularly style nuts on. (Cheaper than lug nuts)
    Even experienced the same thing with the screwdriver. Lol.
    I tend to be “the only” person around when I work on things.
    Not sure getting married would be worth it just for “temporary” help?
    Jimmyh and 12TRDTacoma like this.
  8. May 20, 2020 at 4:13 PM
    TnShooter
    Deogee
    STOCK
    Lol. Yes. Yes it should.
    I can honestly blame auto-correct on this.
    Unfortunately, there is no way to edit Poll choices.
    Mods.....can we get this fixed?
  9. May 20, 2020 at 4:13 PM
    Iconic_
    Iconic_ Well-Known Member
    '07 FJ
    With somebody on the brakes.
  10. May 20, 2020 at 4:15 PM
    TnShooter
    Deogee
    STOCK
    I added that as an option.
    I’m single, I haven’t had the luxury of a helper much.
    Although, I guess wedging a bar between the seat and pedal might work?
  11. May 20, 2020 at 4:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I used a big heavy rock from our backyard on the brake pedal. Put enough pressure on the brakes to torque the axle nut down.
  12. May 20, 2020 at 4:18 PM
    TnShooter
    Deogee
    STOCK
    Lol. I don’t doubt it.
    whatstcp[QUOTED] likes this.
  13. May 20, 2020 at 4:19 PM
    TnShooter
    Deogee
    STOCK
    Was the truck running with help from the brake booster?
    Or off, cause that was a heavy rock of it was off?
  14. May 20, 2020 at 4:21 PM
    eon_blue
    Azusa, CA
    Yeah I popped it in neutral and turned it on (rear wheels chocked of course)
    TnShooter[QUOTED][OP] likes this.
  15. May 20, 2020 at 6:06 PM
    Iconic_
    '07 FJ
    I've tried the bar. In my case it was not enough pressure to stop mine from spinning 'cus they were stuck pretty tight. Somebody had to go full-on the brakes. And they're Wilwoods. :eek:
    I'm single too! :cool: No excuses! :thumbsup:
  16. May 20, 2020 at 6:16 PM
    TnShooter
    Deogee
    STOCK
    No excuses? Lol
    If you got $100 to spare. I might consider this :rofl:
    She’d be in for a surprise when I show her the “Axle Nut” lmao.
  17. May 20, 2020 at 7:31 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    This is the correct answer.
    If you don’t have an impact yet, but work on your own truck, you’re missing out.
  18. May 20, 2020 at 8:04 PM
    TnShooter
    Deogee
    STOCK
    I have both Milwaukee 1/2”
    One is 450 ft/lb the other is 1,000 ft/lb
    I use them a lot. But not to achieve proper Torque Spec.
    There was a time I blasted it all down with an Impact gun.
    Fortune tends to side with the ones that do not know better.
    Misfortune is often found when one knows better, but proceed any way. (This is me)
    Now, I know better. And tend to go by Torque Spec. on the important stuff.
    dk_crew likes this.
  19. May 20, 2020 at 8:24 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Nalgene bottle wedged between the pedal and lower dash. Money.
    SR-71A and Crom like this.
  20. May 20, 2020 at 8:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I hit it with my Makita at full charge when I don't have an impact and air compressor on hand. 118 ft. lbs. Of ugga uggas. Good enough for me. Shit isn't going nowhere. Especially with the cotter pin there to prevent it from backing out.
    Crom, Naveronski and TnShooter[OP] like this.
