What mod or mods voids the warranty?
Discussion in 'Off-Roading & Trails' started by LocoTaco, Jul 22, 2012.
  1. Jul 22, 2012 at 7:09 PM
    LocoTaco
    LocoTaco [OP] Well-Known Member
    Don
    Central Washington
    09 SR5 TRD Sport
    I have a 2009 SR5, TRD Sport, access cab Tacoma, V-6, 6 speed manual, I have had this rig since about a month ago and love this truck.
    What mods can be done and not void the warranty?
  2. Jul 22, 2012 at 7:13 PM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    TRD Double cab, Long box
    Roof Rack, Step Bars, Hood deflector 265/70/17 Goodyear DuraTracs
    I think you can do what ever you want, but if something wears out and they investigate it and determine the mod caused it then they will not warranty it.
  3. Jul 22, 2012 at 7:14 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The manufacturer must prove that aftermarket modifications, parts, or labor were the proximate cause of a failure for the warranty to be denied.
    The manufacturer is not liable for warranty repairs on aftermarket parts or labor.
    There is no such thing as "voiding" your warranty (extended service plans are a whole separate issue and MAY be voided subject to the terms outlined in the fine print).
    If you replace your air filter with a CAI, Toyota may be able to void your engine warranty if they can show (and it's easy to do) that the CAI allowed more dirt to enter the engine, but if your transmission blows, they can not use the CAI as an excuse to avoid repair.
    However, larger tires without corrective regearing may be used as a reason to void the trans warranty.
