What Models/Years have 5spd and shift 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by greenmonkey, Apr 23, 2012.
  1. Apr 23, 2012 at 9:31 PM
    greenmonkey
    greenmonkey [OP] Member
    I am trying to figure out what years and models (cab sizes) come with manual transmission and shifter for 4x4. Any help would be greatly appreciated.
  2. Apr 23, 2012 at 9:45 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I don't believe that Double cabs were offered with manuals until the second generation.
  3. Apr 23, 2012 at 10:34 PM
    greenmonkey
    Do all of the 2nd gens have shifters for 4x4?
  4. Apr 23, 2012 at 10:44 PM
    Warhorseforever
    Will
    Sand Lapper
    I believe that all the 2nd gens have the knob for 4x4 and no shifter available even as an option. Crawler box and FJC case swaps have been done plenty of time though.
  5. Apr 24, 2012 at 12:16 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Every model had a 4x4 and manual transmission option. Also, every 4wd model has a transfer case shifter for high to low gear. Some of them have the manual 2wd/4wd J shifters but that was slowly phased out and replaced by an electronic push button 4wd (button located on the t-case shifter).
  6. Apr 24, 2012 at 12:24 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I was always thought first gen double cabs only came in automatic...:notsure:
  7. Apr 24, 2012 at 8:06 AM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    I have a friend that has a 1st Gen Tacoma (2001 to be exact) and his transfer case does not have the manual shifter—he has the electronic push button to switch to 4 wheel drive.
    With that said, I was/am still under the impression that 2000 was the last year for the manual 4x4 shifter.
    I could be wrong though :cool:
  8. Apr 24, 2012 at 8:13 AM
    shaniac
    Charleston, SC
    It does however, in order to engage the 4 wheel drive system he has an electronic button that he pushes.
    In my 2000 Taco, my system is completely manual. :cool:
    I probably should have been more clear in my original post...he does have a high/low shifter but with an electronic button to engage the system.
  9. Apr 24, 2012 at 8:14 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    ALL 1st gens (1995.5-2004) had manual 4x4 shifters. Some had a button on the manual shift lever to switch into 4hi, but had to be manually shifted into 4lo. This was a factory option and most 1st gens had the full manual 4x4 shifter (J-shifter).
    All 1st gens had the option of a 5 speed manual with the exception of the double cab v6. There are a few double cab 4 cylinders out there with factory 5 speeds.
  10. Apr 24, 2012 at 8:21 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
  11. Apr 24, 2012 at 1:33 PM
    haddix
    haddix Well-Known Member
    KY
    07 FJ Cruiser
    OME,315 k02, custom bumpers
    Single and ext cab were offered with a manual transmission. Double cabs are all autos unless you swap a 5 speed in yourself. Some have a j shifter and some have push button 4wd but you still have to manually shift for 4 lo even with push button.
  12. Apr 24, 2012 at 1:45 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I spy lady foot
    :spy:
