What mods could void your warranty ? Any experience with this ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jakobsmirnoff, Sep 7, 2021.
  1. Sep 7, 2021 at 10:10 AM
    Jakobsmirnoff
    Jakobsmirnoff [OP] Well-Known Member
    Ron
    Winnipeg, Canada
    2021 Sport MT Barcelona Red 2020 GR Supra 3.0 Black on Black 1973 Corolla 4 speed
    TRD Suspension, TRD Ehaust, TRD Wheels,
    I just purchased a 2021 TRD Sport and will be putting larger tires on. I'm wondering if they could void the warranty on the ABS or axles etc if I had a problem.
    What if I change any lights, like taillights or install an aftermarket car starter ?
  2. Sep 7, 2021 at 10:25 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Mods don't void warranties, the manufacturer simply doesnt warranty aftermarket products or breaks/wear as a direct result of the aftermarket part.
  3. Sep 7, 2021 at 11:32 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    To build on what JoeCOVA stated, a dealer could refuse to cover a repair under warranty if they can prove an aftermarket part caused the need for the repair. For example, if you lift your truck with something other than the TRD lift kit which is Toyota authorized and then have a suspension related failure on an OEM suspension part, or you have an OV Tune or KD Max tune installed and then have an engine or powertrain issue. Key word here is could...some dealers will work with you, but most will take the out if they get the chance. Mods will not void the entire warranty. A dealer won't refuse to fix your windshield wiper motor if you have a lift or larger tires installed. It has to be directly related to the failure.
    Don't forget, a lot of this depends on the dealer. Most, for example won't go poking around your ECM (or may not even be able to) if you come in for a routine warranty repair on something fairly insignificant. If you come in with a blown engine or trans, odds are that ECM will be going to Toyota, and they will poke and be able to tell it was tuned. Mods are a calculated risk as far as warranties are concerned, and only you can decide if the risk is worth the reward.
  4. Sep 7, 2021 at 11:46 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Stated simple anything you do that causes a failure is not warranty! Like run the engine out of oil No antifreeze in the engine below freezing Install a remote start system that melts the wire harness and the fault can be traced to your new system.
    Then being all dealers are independent you never know if you buy 20 New Vehicles a year from that dealer things might get over looked .
    In the early days I fixed a few Tacoma frames never any issues getting the trucks bought back
  5. Sep 7, 2021 at 2:44 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Always figured splicing into wiring harnesses could cause trouble down the line. I paid a little extra for the OEM hatch locking mechanism instead of a Pop and Lock so it plugged in rather than spliced in.
  6. Sep 7, 2021 at 2:48 PM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    MIDTNTACO, ndoldman59 and Hank Heel like this.
  7. Sep 7, 2021 at 5:31 PM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    mmhmm.
    MIDTNTACO likes this.
  8. Sep 7, 2021 at 5:35 PM
    Jakobsmirnoff
    Ron
    Winnipeg, Canada
    I did too although I believe the oem is made by pop n lock
  9. Sep 7, 2021 at 6:36 PM
    AZPhys13
    I think you're right but those OEM connectors were nice
  10. Sep 7, 2021 at 7:08 PM
    Jakobsmirnoff
    Ron
    Winnipeg, Canada
    You'll have Toyota warranty on them at least !
