What mods should I do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Jul 13, 2018.
  1. Jul 13, 2018 at 3:15 PM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Howdy, I just got my last extended warranty check up, which was at 45K miles. All the oil changes, filter changes, rotations, etc will now be out of pocket. What do you guys recommend I do? Should I go for synthetic oil? How often do I change it out? Should I put some K&N oiled filters in there? Should I put some dry ones? Should I just get the whole K&N intake? How often do I clean those filters out? I also wanna try and save a little gas, I went from 14mpg to 18mpg (sometimes 16mpg depending on the climate) by simply doing what someone else here mentioned of not revving it past 2000 rpms. I just got a throttle body spacer, but have yet to install it. Is there something else I can add to see an increase in mpg? Thanks in advance guys!
  2. Jul 13, 2018 at 3:21 PM
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    How one never gets above 2,000 RPMs is beyond my comprehension ?
  3. Jul 13, 2018 at 3:28 PM
    Wixo
    Hank
    Tint, LED interior
    Well I just accelerate slowly but not too slow. Sometimes the transmission gets stuck in a lower gear so I pump the gas a tiny bit and sure enough it lowers the RPMs.
  4. Jul 13, 2018 at 3:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Read this https://www.tacomaworld.com/threads/mpg-fyi-why-your-tacoma-gets-what-it-gets.558085/ I wrote it for posts like yours.
    Oh, your truck came with synthetic oil and all 0W-20, which is what belongs in your truck, is synthetic.
    Air filters, spacers or different intakes will not help with mpg. Driving style is only change you can make.
    As far as you not exceeding 2K rpms, how many hours does it take you to get to 60 mph?
  5. Jul 13, 2018 at 3:36 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    The specs require synthetic so obviously you should use full synthetic. Other than that, do whatever mods you want! Have fun.
    DubfromGA likes this.
  6. Jul 13, 2018 at 3:45 PM
    Wixo
    Hank
    Tint, LED interior
    I didn't really make it for gas saving tips. I made it more so that I know what type of filters/oils I would need to run in the truck to get the most life out of it and what kind of maintenance they require. so far I've been changing the oil every 10K miles. Does that sound about right? If I get some oiled/dry filters how often do I need to cleen/oil them?
  7. Jul 13, 2018 at 3:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did your truck come with an owners manual?
    Hard to go wrong with that for your lubricant specs, intervals and filters.
    There are very few 'mods' that will improve MPG. Lots of things folks fuss about on the 3rd gen are actually caused by Toyota trying to bump up MPG for the EPA goals.
    However, the Corolla conversion is guaranteed to help with MPG :thumbsup:.
    StayinStock, DubfromGA and shakerhood like this.
  8. Jul 13, 2018 at 4:12 PM
    ICU1
    ICU1 Well-Known Member
    Free mod. Put your service department phone number in your phone
    StayinStock and shakerhood like this.
  9. Jul 14, 2018 at 8:37 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Use Toyota filters, and whatever synthetic oil blows your hair back. The filter is important, so don’t cheap out on it.
    StayinStock and ICU1 like this.
  10. Jul 17, 2018 at 2:37 PM
    Wixo
    Hank
    Tint, LED interior
    Ok so I already ordered a corolla engine. Should I get a corolla transmission too? Or will it do fine with the original Tacoma transmission?
  11. Jul 17, 2018 at 2:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Cheaper to get the whole running car. :D
    A 2000 model should be cheap to buy and do great on the MPGs. :thumbsup:
  12. Jul 17, 2018 at 2:59 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Just follow the maintenance intervals located in the manual.
    As far as MPG. Keeping RPMs low or driving like a littler old lady going to church wont save MPG.
  13. Jul 17, 2018 at 3:33 PM
    Wixo
    Hank
    Tint, LED interior
    Well my monthly gas bill just went from $500+ down to the low $200s by driving slower so...
  14. Jul 17, 2018 at 3:36 PM
    JoeCOVA
    Joe
    Colorado Springs
    I drive every car I have ever had like a race car fast acelleration and late hard braking and I manage 19.5.
    I averaged 18.7 going up to 10.000 feet with RPMs at 3500-4000
    Best of luck.
  15. Jul 17, 2018 at 3:41 PM
    Wixo
    Hank
    Tint, LED interior
    I used to drive my diesel jetta like that and got 25+
  16. Jul 17, 2018 at 3:44 PM
    JoeCOVA
    Joe
    Colorado Springs
    We all know your numbers are bullshit because if your gas cost went down by more than double that means you stopped buying gas or your MPG went up by more than double so you averaging 30+ mpg?
    $500 monthly gas to low $200s by using low revs HAHAHA.
    I'm out before I do something to get reported
    WSW3 likes this.
  17. Jul 17, 2018 at 3:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    K&N filters are a waste of money. They don't improve fuel mileage. They do add a few HP, but only if you're driving in the 5000 rpm range. In other words in a race car they MIGHT net you 2-3 more MPH on the top end. That MIGHT make the difference between 1st and 2nd place. But in an every day vehicle they don't help. In fact they don't filter the air as well.
    Use synthetic oil. Do what you're comfortable with, but lots of folks, myself included change synthetic at 10,000 miles. I'm at 190,000 and have been doing that since new and I've never added a drop of oil between oil changes. There have been people posting here with double that many miles that did the same.
    Drive sensibly, but don't get hung up on 2000 rpm's. Although that isn't a bad rule of thumb. But there are times when you need to rev up the engine. I've never owned a vehicle that wouldn't at least match the EPA estimates, and sometimes I exceed them. And I often drive 70 mph on the hwy. I just don't try to set a new 0-60 time getting there. That will kill fuel mileage. I'm usually between 2000-2500 rpm's and still get just under 20mpg. With a 4X4 DC.
  18. Jul 17, 2018 at 4:59 PM
    tn111
    tn111 Well-Known Member
    2018 TRD Sport 4x4 MT
    How are you only getting 18mpg if you never go over 2,000rpm?
  19. Jul 17, 2018 at 5:46 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I would assume any of the mods that swing that way!
  20. Jul 19, 2018 at 12:59 PM
    Wixo
    Hank
    Tint, LED interior
    Honestly, I changed a couple other things. I dont floor it to try and beat the slow start person who only goes 55 in a 55 when I want to do 60. I dont drive 85 in the passing lane I do 68 in the middle lane, and if some guy is doing 65 I dont floor it to pass him and do 68 right infront of him. Ive also been driving just a little bit less lately. So thats what im attributing to less gas consumption.
