What month was your 2016 built?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by keithert, Mar 2, 2016.
  1. Mar 2, 2016 at 11:55 AM
    keithert
    keithert [OP] Well-Known Member
    Just wondering when peoples 2016 Tacomas were built vs when you bought them. I bought mine on February 19 and it was built in January of 2016 per the sticker on the driver door jamb.
    I'm also curious to see if more recent builds have fewer issues. Mine did have the transmission fluid low.
  2. Mar 2, 2016 at 12:03 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Built in in Texas November , driven off the lot Nov 22. It had low tranny fluid which was checked by dealer and topped up, but I think it's still low, so going back in for a 2nd look.
  3. Mar 2, 2016 at 12:44 PM
    rrentrop
    rrentrop TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Baja-built Limited with production date 9/15. Drove it home on 9/15/15. Only issues so far was failed BSM sensor, cracked 3rd brake light lens and bezel, and it was one of the 306 that were recalled for the knee airbag panel bolt issue.
  4. Mar 2, 2016 at 12:49 PM
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Build date 9/1/15 and bought it on 9/26/15. Haven't had any issues with it beside them replacing a loose window seal on my rear driver door under warranty other than that the trucks been amazing!
  5. Mar 2, 2016 at 12:51 PM
    asiantaco 253
    asiantaco 253 Well-Known Member
    PNW
    2016 Toyota Tacoma Inferno DCLB TRD Offroad
    Built in Mexico jan 19 and drove off the lot feb 4.
  6. Mar 2, 2016 at 12:51 PM
    madcop94
    madcop94 Well-Known Member
    Northern Maine
    2016 TRD SPORT 4x4 DCLB Silver Mist
    Window tint, BF KO2's
    Built 12/26/2015 in Texas bought it February 15, 2016, no issues yet.:fingerscrossed:
  7. Mar 2, 2016 at 1:08 PM
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Build date 9/2015 drove of the lot 10/3/2015 no issues. Texas Truck
  8. Mar 2, 2016 at 1:10 PM
    keithert
    Where are you getting the actual build date? The door jamb just shows the month.
  9. Mar 2, 2016 at 1:11 PM
    sadmrhappy
    sadmrhappy <insert clever title>
    cylinder 0, head 0, sector 1
    2016 Inferno Tacoma DCSB TRD Sport 4x4
    Build Date 01/16, Texas Plant. Purchased 02/16. Transmission fluid was 3/4 quart low, no major issues.
  10. Mar 2, 2016 at 1:11 PM
    baron55
    My mistake corrected.
  11. Mar 2, 2016 at 1:15 PM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    10/2015, Mexico plant.
    So far it has:
    1. Howling, even with lower control arms being taped. Particularly at high speed and in wind (all week in KS).
    2. Erratic shifting between 4th, 5th and 6th on highway. 3,200 RPM at 72 MPH on highway regularly without much wind and flat with cruise on.
    3. Sport hood scoop not staying down and has black line from drivers POV.
    4. Fender flare not flush on passenger side.
    5. Rattling dash on passenger side, not glovebox insert.
    6. Shifting from reverse/neutral to drive sometimes delays the first time truck is started and lurches forward.
    7. Some driveline vibrations in the 2k-2,500 RPM range.
    And probably some other things. But you know what, I still love it and it's the first year. I'm just making a list for my 10,000 mile service and I'll just drop it all on them then, haha. Might have low ATF fluid, sound seems to come from around the window because if I roll it down just a hair it's gone. Control arm tape fixed the low speed sounds for the most part, but it still occurs occasionally.
    Purchased 12/14/2015. I'm at about 6,800 miles now.
  12. Mar 2, 2016 at 1:27 PM
    NV_Tacoma
    Paul
    Northern Nevada
    On my service paperwork from Toyota, it gives me the actual date.
  13. Mar 2, 2016 at 1:42 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    Built 02/16, Mexico I think (VIN starts w/ 5). Purchased 2/20/16.
    Haven't check trans fluid yet, but then I also have none of the symptoms of low trans fluid.
  14. Mar 2, 2016 at 2:09 PM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    If your VIN starts with a 5, it was built in Texas. Baja trucks start with a 3.
  15. Mar 2, 2016 at 2:19 PM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    1/16 build, 2/16 bought (day after it arrived at the dealer)
  16. Mar 2, 2016 at 2:19 PM
    UtahUtes
    UtahUtes Well-Known Member
    Erik
    Iowa
    2016 DCSB OR MT
    Built in February 2016 in Texas, DCSB OR 6MT
  17. Mar 2, 2016 at 3:26 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    11/21/2015 in Baja-- took delivery 12/03/2015
    DCSB TRD OR 4x4 Auto Trans
    1. exhibiting some transmission slipping issues and clunking upon downshift when rolling to a stop
    2. something rattles under the rear of the truck bed when I slam the back drivers side door shut
    3. howling from control arms on occasion
    4. zerks were dry from factory (dealer lubed at 5k service)
    5. Analog Speedo is off about 1 to 2 mph from the digital read-out
    6. Analog Speedo started "Ticking" instead of smooth normal operation the other day on freeway at speeds over 55mph upon acel and decel
    7. Adhesive under hood separating in a couple of spots but hood not really "vibrating" as some have noticed on their trucks
    8. Gas mileage about as good as a 2nd gen (on flat and straight Phoenix roads) despite trying to drive like a grandpa
    9. transmission/motor combo feels gutless unless pushing ECT when compared to my gal's 2016 4Runner SR5 Premium
    Other than that I like the truck.
  18. Mar 2, 2016 at 3:56 PM
    toyota16
    toyota16 Well-Known Member
    2016 Inferno TRD Off Road 4x4 Double Cab 5' Bed w/JBL Premium Sound & and Technology Package
    Warn Semi-Hidden Kit Winch Mounting Systems 100044 DOBINSONS 2.0″ LIFT KIT DSSKIT22 Coils (C59-352 2" 110-240 front end load) Falken Wildpeak at3w 265/75r16 10 ply knurled radio knobs, machined aluminum, black anodize finish Dash top Multi-Mount with Ram Mount X-Grip Husky Liners Front 13951 & Rear 14951 N-Fab wheel to wheel T1580CC Toyota Black Out Emblem Overlay Kit PT948-35180-02 Toyota Bed Cover F-44x9-1200-ahxx Toyota Bed Mat PT580-35050-SB Toyota wheel locks PTR27-35100 Toyota Chrome Tip PT932-35162 Toyota Bed Divider PT767-35051 K&N Air Filter 33-5017 weather Tech Mud Flaps 110055 - 120055 Avs Bug Shield 25681 Avs Window Vents 94768 Cali Raised Led Light Bar 31.5" light bar in the lower bumper Suntek Window Tint on the front to match the factory rear
    Baja-built TRD off road with production date 9/15. Drove it home on 9/26/15. No issues so far 10k miles
    Cuffs and Robbi3rob like this.
  19. Mar 2, 2016 at 4:10 PM
    CRIMAR30
    CRIMAR30 2016 TRD SPORT
    MARK
    NORTH CAROLINA
    2016 TRD SPORT ACCESS CAB
    Built 11/2015, delivered 11/19/2015, built in Texas. Truck was wondering when I got it, had dealer check alignment, all is well now. How do any of you know your transmission fluid is low?
  20. Mar 2, 2016 at 4:11 PM
    Howen
    Howen Well-Known Member
    2016 DCSB OR M/T black w/Leer 180
    DCSBORMT, Feb 4 (a Thursday, I think) build date, 600+ miles. No real issues except the one about trip odometer resetting, and some crap about Sirius unable to connect for FM stations. I blame that more on Entune than Toyota. And, the second to third gear shift (manual) is notchy, often sounds like clutch pedal not depressed enough. Plan to try to remedy that with Redline gear oil.
    Very satisfied overall. Two weeks into it, and still looking forward to every morning.
