what mpg do y’all get
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Oct 25, 2023.
  1. Oct 25, 2023 at 4:53 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    What do y’all get mpg “. I have a 2007 4 cylinder 2wd babe and I get about 315 miles from a tank. Yes It has 3” lift and bigger aggressive tires. before the lift and bigger tires I use to get 505 miles from a tank. I know it sucks and that’s big difference
  2. Oct 25, 2023 at 5:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    315 or 505 miles/tank is meaningless info. Figure your MPG's and get back with us.
    My 07 4X4 DC 4.0 auto gets 17ish mpg for everyday driving. Right at 20 mpg hwy and on rare occasions when everything lined up right as much as 22 MPG. I have slightly oversize 265/75/16's on it. I've had E rated tires in the same size and it made no difference in fuel mileage.
    I don't run mine much below 1/4 tank so have no idea, nor do I care, how far it will go before running dry. But in theory a 21 gallon tank @ 20 mpg should go a little over 400 miles on the hwy or about 350 miles for everyday driving. I have never gone much over 300 before buying fuel.
    Elikk, ridefreak, Travlr and 5 others like this.
  3. Oct 25, 2023 at 6:13 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Johnny3rz and FMRAV4 like this.
  4. Oct 25, 2023 at 7:29 PM
    Nazareth7
    2007 Tacoma 2x4
    I just told you everything in the post , maybe you’re ignorant but let’s see other experts
  5. Oct 25, 2023 at 8:15 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Marshall R is absolutely correct, the number of miles per tank is completely useless information. You start by asking about miles per gallon and then you talk about miles per tank. They ain’t the same and one doesn’t have anything to do with the other. To repeat miles per tank is pretty much a meaningless measurement. As far as ignorance perhaps you should look in the mirror.
    Charlie Bravo, tacoman45, E3g and 6 others like this.
  6. Oct 25, 2023 at 8:22 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
  7. Oct 25, 2023 at 8:33 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    It’s just much more accurate to write your miles and fill your tank, when you refuel the next time divide the miles by the gallons used to fill it up. By tank is fine but again just not as accurate.
    jaydeebee likes this.
  8. Oct 25, 2023 at 8:35 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    18.x MPG on my 4.0L V6 supercharged.
    2.5” lift, 255/75R17 load range C KO2s.
    300lb camper on rear.
    miles per tank? No idea since I don’t run it dry and overheat the fuel pump.
  9. Oct 25, 2023 at 8:47 PM
    Nazareth7
    2007 Tacoma 2x4
    You sound like a child. And you’re as ignorant as your buddy.
  10. Oct 25, 2023 at 9:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When do you fill up? When the gas light comes on? Is there a gas station immediately available as soon as the light comes on? Do you bury the needle down past E? How buried are we talking? Still touching the last hash mark, or completely past it? Some people fill up at 1/4 tank. Some people (like me) drive around with the gas light on constantly because I'm lazy and procrastinate
    Like it or not, miles per tank is not a very effective way of comparing mpgs. It's the same thing as measuring lift height from the ground to the body instead of center of hub to fender.. a change in tire size throws everything off
    The correct way to calculate fuel mileage is to write down miles driven and gallons filled whenever you fill up. Doesn't even matter when you fill up. Could be half tank, 1/4 tank, whatever. Fill it up till it clicks off. Divide the miles driven by the gallons used and repeat for a few weeks. That is some math that everyone can use and share over the internet
  11. Oct 25, 2023 at 10:32 PM
    ThatsExactlyWhy
    ThatsExactlyWhy Well-Known Member
    NorCal
    2019 OR 4x4 MT
    OP seems to be a little loose with his terminology but it is false to say MPG and miles per tank are completely unrelated. Downright ignorant to say that miles per tank is completely useless info.
    I pay close attention to how many miles I can get out of a tank. Obviously not so I can run the tank dry, but to know whether I can make it to Costco and save a few bucks on my fill up or I gotta fill up in town
    so for what it’s worth, I can reliably get 400-420 miles out of my tank. I’ve gotten as much as 450. I average between 18-20 mpg regularly. Higher on long highway trips. Best on a single tank was 21.9
    Never actually run out of gas (in the Taco that is), but I always look at how much the tank takes to see how “close” I came for future reference. So far, don’t think I’ve pulled in with less than 1/2 gallon
  12. Oct 25, 2023 at 10:40 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Happy Friday
    jaydeebee, ace_10, E3g and 2 others like this.
  13. Oct 25, 2023 at 11:20 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I was going to give a serious response to the OP topic including charts of my hard data but based on your attitude I changed my mind. Don’t be a dick.
  14. Oct 25, 2023 at 11:22 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    Damn what's the secret, I get 15.5 mpg in my 07 4x4 v6 auto- bigger tires but no lift. Are my ditch lights causing that much drag? Lol. I got 17 mpg highway when I swapped-on some free 3rd gen takeoffs...
    xguntherc and Hayden334 like this.
  15. Oct 26, 2023 at 1:53 PM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Or use the Fuelly app. I started using it a little over a year ago. Hands down the easiest way to keep track of MPG. see below, I am on a 2" lift with 285/70 R17's
  16. Oct 26, 2023 at 3:29 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    2012 4.0l V6, auto trans, 4x4, full steel skids, plate bumpers front and rear, bed rack, 4.56 gears, 33" skinnies, 14mpg is as good as she gets!
    15ACOR and DriverSound like this.
  17. Oct 26, 2023 at 3:37 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Not sure, I dun heared "y'all" wuz agetten' 46mpg but thats only when a-usen' spongy gas. My measurin' stick can be tricky to use
    Hayden334 likes this.
  18. Oct 26, 2023 at 3:42 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    this what the hell lol
    i get not comparing the two because of certain factors but to say they're unrelated? lol obviously miles per tank is not a consistent/reliable measurement unless all other factors are constant, but anyone with half a brain can use the "miles per tank" compared with how much they fill up at their next gas stop to determine their MPG. Fill your tank, reset the trip meter, drive until you fill again, and do some basic math
    To answer your question OP, I get about 240/270 miles per tank, usually filling up at 1/8th of a tank. depending on the driving conditions and how heavy my foot is feeling. Sometimes less if it's a lot of steep climbs. 2014 4x4 V6 double cap with a whole bunch of extra weight added onto it. Calculating my actual MPG based on fillups it usually averages around 13-14...which tracks pretty closely with the miles per tank.
    mojojojo78 likes this.
  19. Oct 26, 2023 at 3:44 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    12-14 on a good day. 10-12 lots of stop and go. Rarely do I see 300 miles to a tank.
    Aardvark13 and mojojojo78 like this.
  20. Oct 26, 2023 at 3:49 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    None existent.
    mojojojo78, Hayden334 and TacoTyusday like this.
