What needs replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Apocojules21, Nov 30, 2011.
  1. Nov 30, 2011 at 12:15 AM
    Apocojules21
    Apocojules21 [OP] Member
    I currently got my chenck engine light on and went to autozone to get the codes that trigger it.
    The following codes came up:
    P0171
    P1130
    P1135
    I have a 2000 toyota tacoma. I cleaned the MAS and replaced the O2 sensor but I the check light engine keeps turning on.
    My gas miles decrease noticeably.
    The new codes that I got were
    P0171
    P1130
    P1133
    I am planning to replace the fuel filter, hoping that will take care of it. It appears that there are no air leaks.
    Can someone advise or has dealt with something similar before that they can share the solution.?
  2. Nov 30, 2011 at 6:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What 02 sensor did you replace? There are TWO of them.....In most cases, its the BANK 1 SENSOR 1 which is the sensor before the CAT on the engine side.
    Also, take your gas cap off and then put it back on. This has been known to trigger some CEL lights (it's weird...but true).
    Can't help ya with the rest...You can google it or research the forums.
    Welcome to the forum BTW!!!
  3. Nov 30, 2011 at 9:04 AM
    Apocojules21
    I replace the O2 sensor by the exaust at the bottom on the engine. Where is the other Sensor? (Bank 1 Sensor) I believe that is my ready out.
    Thank you,
  4. Nov 30, 2011 at 9:50 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    I belive P0171 is for the MAF sensor on the side of the intake tube. I cleaned mine and it went away, just take it out and clean the little wires inside with Electronics cleaner spray let dry and put back in. P0130 is the sensor Before the CAT
  5. Nov 30, 2011 at 9:59 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    P0171 is the lean fuel trim code. As Anthony stated, cleaning the MAF should take care of it. If that doesn't work, I would suggest looking into the AFR (Front O2 sensor). It will be located in front of the CAT.
    The other two codes are AFR specific. They could be a result of the first (P0171) code
    Things to note:
    Bank 1 = side of the motor with the number 1 cylinder.
    Bank 2 = side of the motor with the number 2 cylinder.
    Sensor 1 = forward most sensor
    Sensor 2 = rearward most sensor
  6. Nov 30, 2011 at 10:11 AM
    Janster
    Jandy
    Lancaster, PA
    This is a picture of BANK 1 SENSOR 1 (on a 96 3.4L)
    This is a picture of BANK 1 SENSOR 2 (on 96 3.4L)
    It might look different on yours, but this should give you an idea....GOOD LUCK!
  7. Nov 30, 2011 at 10:56 AM
    Apocojules21
    Thank you for your input.
    I did cleaned the MAF and change the O2 sensor in front of the CAT. Are both sensors the same. Meaning, if I bought the back sensor and put it in the front, will the sensors be any different.?
    I am in the process of changing the Fuel Filter.
    Does anyone have the installation instructions?
    I try to look it up in the repair book but there was nothing on changing the Fuel filter.
    The worry is the gas that will leak after unscrewing the filter screws.. I do not know which is the relay that need to be taken off so the fuel line get cleaned of gas.
  8. Nov 30, 2011 at 11:41 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The sensors look the same, but will give different readings to the ECM. Chances are, putting the rear upfront with only cause another code to trip.
    You will have some gas loss but only what gas is in the fuel line.
    What truck are we dealing with here? Motor? Cali Emissions? Auto? Manual?
  9. Nov 30, 2011 at 11:53 AM
    Apocojules21
    2000 Toyota Tacoma prerunner, 2.7L (Inline 4), Cali emissions.
  10. Nov 30, 2011 at 11:58 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    What brand sensor did you buy?
  11. Nov 30, 2011 at 12:29 PM
    Apocojules21
    Afer market:
    [FONT=74wxc,Bold][FONT=74wxc,Bold][FONT=74wxc,Bold]2000- Toyota- Tacoma-
    2.4L Engine - Calif
    Emissions - Extra Cab -
    Pre-cat Oxygen
    Sensor
    [/FONT]
    [/FONT]
    [/FONT]
    [FONT=74wxc,Bold][FONT=74wxc,Bold][FONT=74wxc,Bold][/FONT][/FONT][/FONT]
