What?! No DIY for Leaf Pack Replacements?
Discussion in 'Suspension' started by TacomaMtnMan, Jun 20, 2013.
  1. Jun 20, 2013 at 11:37 PM
    TacomaMtnMan
    TacomaMtnMan [OP] those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    Okay,
    I know its probably easier to replace the leaf packs than doing an AAL. But did I miss a thread about this? More specifically what are the torque specs for attaching the new springs with new bushings?
    I am looking at the Alcan 3.5 inch lift springs with the 2.0 or 2.5 Rear Fox Shocks with reservoirs.
    I just want to be sure I purchase the right setup, would the 10 inch travel shocks be correct? Extended length: 26.10" | Collapsed length: 16.10"
    Lastly, do I need the brake line extensions?
    Is an AAL system just as comparable as a leaf pack?
    Thanks in advance!
    ~ Chuck
  2. Jun 20, 2013 at 11:39 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    i would go with new packs over AAL and i dont think you need a extended rear brake line but i am not 100% sure on that
  3. Jun 21, 2013 at 12:20 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    If you're going to running that much lift and travel I'd get the extended brake lines...
  4. Jun 21, 2013 at 2:47 PM
    TacomaMtnMan
    Chuck
    Broomfield
    Yeah better safe than sorry. So did anyone have the AAL and then get a leaf pack... did you see a ride difference?
  5. Jun 21, 2013 at 2:58 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    If you look at the OME install sticky, it includes replacing the leaf pack.
  6. Jun 21, 2013 at 10:38 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    87 ft lbs IIRC for eye bolts.
  7. Jun 24, 2013 at 9:20 PM
    TacomaMtnMan
    Chuck
    Broomfield
    Thanks Ronn!
    Does anyone have Alcan springs with any feedback?
