What octane are you running??
Discussion in 'Performance and Tuning' started by 1TUFFTRD, Feb 8, 2010.
  1. Feb 8, 2010 at 5:31 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Just curious on what octane gas you all are running in your yota and why?Do you feel a difference with higher octane?better gas mpg?I'm personally running 91(highest in cali) just like to treat my taco right!!what about you?
  2. Feb 8, 2010 at 5:36 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I run 87 oct. consistently--Any time I've run higher, it loses mpg's. I know, sounds backwards, but it's fact for me. Many folks have reported the opposite results though. :confused:
  3. Feb 8, 2010 at 5:38 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    crazy! do you prefer certian gas company's over others?
  4. Feb 8, 2010 at 5:42 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    I run 87. I've tried maybe a tank or two each of 89 and 91, but noticed no difference. My truck likes the 87 and I'm very happy with the gas mileage I get out of it. Also, the manual says to use 87, so that counts for something...
  5. Feb 8, 2010 at 5:44 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    thats coo... my manual says at least 87 and testing was done on 91?
  6. Feb 8, 2010 at 5:46 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    87. The trucks are tuned to running 87 the most efficiently. When I put 91 in, it feels no different. Unless you run racefuel... 97 octane and higher, your increased performance is negligible, anything otherwise is pseudo feeling.
    91 in the M3. It is tuned to run 91. When I put 87, it feels like crap and pings.
    Also, there's a crapload of threads on this same topic. OP (original poster) do a search... what's been said here has been said over a dozen times.
  7. Feb 8, 2010 at 5:49 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Usually 94 Sunoco. I think there is less methanol in the higher octane, and the mileage seems to show it. Methanol = :turtleride:
  8. Feb 8, 2010 at 5:52 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    Thanks for the tips
  9. Feb 8, 2010 at 5:53 PM
    carmellocafe
    KEVIN
    N. California
    Just been using "QuikStop" cause it's closest. The thing that has made the biggest difference in getting good mpg's is always using the same station and pump (if possible) each time I fill up. I used to believe pretty heavily in Valero, but ever since I switched to the cheaper (QuikStop) station, I've been doing better. I really don't think there is that big of a difference between gas stations. Although, I've had the absolute worst results with Chevron gas! :eek: I think it might be the techron crap they use.
  10. Feb 8, 2010 at 5:59 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    91 (highest in my area) and only Shell, Exxon, BP.
  11. Feb 8, 2010 at 6:05 PM
    xSpyderguyx
    xSpyderguyx Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    I run the middle grade (89 octane)
    I only use the shell nitrogen gas and the chevron techron gas.
    I stay away from 76 and Am/Pm
  12. Feb 8, 2010 at 6:06 PM
    JohnnyGato
    JohnnyGato God of Thunder ...and Rock N' Roll!
    Vegas Island
    04 TRD SR5 V6 4x4 Off Road
    Limo tint, Sirius/XM radio, Wet Okole's, Weathertech's, Rhino Lining, blacked out badges, shorty antenna, painted speaker (tweeter) covers, blue LED running lights, Icon 3" lift, Pro Comp 17" 7005's, 33" (285/70/17) Good Year MT/R's with kevlar.
    I have been running 87 since I bought it. Runs great too!
  13. Feb 8, 2010 at 6:10 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    :goingcrazy:I have tryed both regular and premium they seem the same. Just the premium makes you think you are faster:goingcrazy:
  14. Feb 9, 2010 at 9:50 AM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    So maybe ill start running some mid grade... but i like to run shell cuz its close and one of the less expensive!
  15. Feb 9, 2010 at 9:52 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Always MOBIL 87
  16. Feb 9, 2010 at 10:03 AM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    manual says 87 so thats what i run and it runs awesome
  17. Feb 9, 2010 at 1:03 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Have you reset the ECU after switching fuel grades (disconnect battery)? Do that, and I bet you see a difference.
    Not true. Our motors have a high CR from the factory (10:1). Higher octane will reduce knock, and allow for more performance.
    Our ECUs are a learning ECU, with a knock feedback system. The knock feedback system is designed to always test the knock threshold to learn the boundaries for spark advance.
    Meaning when you run a higher grade octane, reset the battery and force the ECU to 'relearn' the tune, it will test for higher octane and add more timing. That extra timing = more power.
    Going from 87 octane to 93, will be the same as someone going from 93 octane to race fuel status (99 oct). Per octane point increase you can usually add .5-1.5° of timing depending on fuel quality. Every degree of advance can net you up to 4hp (as long as knock is suppressed) If you add 6° of advance (for 6pt of octane increase), you can add up to ~24hp (supposing the ECU auto-advances 6°).
    Read my previous entry. The trucks are capable of running 87 octane without any problem, it does that by pulling timing. But like I said, our ECUs are self aware, and use a reactive tuning method to check knock thresholds to keep the motor safe.
    Unfortunately you can't really use that in reference to our vehicles. Different ECUs altogether, won't respond in the same way.
    If you are looking for the extra performance, use 91 and reset the ECU, let it learn the new gas. Looking to stay on a budget, nothing wrong with 87.
  18. Feb 9, 2010 at 1:07 PM
    krytikel
    krytikel Well-Known Member
    California
    2017 Tacoma TRD Inferno sport 4X4
    OME lift
    I run 87 on mine...no problems yet:D!
  19. Feb 9, 2010 at 1:15 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Since I live in Germany I am pretty much forced to buy Gas through the Exchange. It is Esso fuel and I have had no problems with it. The lowest that I can buy is 90 so that is what I run. I could go lower but I would have to buy it out on the economy and that just isn't going to happen. On post it is $3.09 a gallon, Off post it is 1.34 Euro a Liter which is equivelant to 4.02 Euro a Gallon or $5.54 a gallon for 87.
  20. Feb 9, 2010 at 3:56 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
