What octane do you run?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicklamie132, Aug 27, 2020.
  1. Aug 27, 2020 at 5:35 PM
    nicklamie132
    nicklamie132 [OP] Member
    Nick
    I have a 2011 access cab V6 4x4 and have been messing around now for a few months with the octane of fuel I run and so far 89 is the best feel it runs smoother and I get better mileage out of a tank around 20 mpg I've figured out mainly city driving with a mix of highway.
    Kolter45 and Rsmallw2 like this.
  2. Aug 27, 2020 at 5:35 PM
    Rawdoggy
    Rawdoggy Well-Known Member
    Spf 30 or 60 depending on the sun
  3. Aug 27, 2020 at 5:39 PM
    Rsmallw2
    Rsmallw2 Well-Known Member
    Michigan
    06 Tacoma PreRunner V6
    I run 87 and it seems to run fine but I have not tried a higher octane.
  4. Aug 27, 2020 at 5:44 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    I run 93 at least once a month with a fuel additive to clean everything up a bit. Try 93, youll find some power lol
  5. Aug 27, 2020 at 5:47 PM
    Rsmallw2
    Michigan
    I'm going on a 500 mile round trip next weekend. I'll fill up with 93 and see if I notice a difference. Thanks.
    rtilton12[QUOTED] likes this.
  6. Aug 27, 2020 at 5:52 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    This comes up regularly and it will be a bunch of anecdotal "evidence" based on how the drivers think their truck feels. Without having a way to monitor the total ignition timing, knock feedback and learning and/or ignition advance multiplier, it's all just conjecture and any real improvement will be minimal, if at all, but may be worthwhile depending on what you value and some parts of the engine design.
    One example, Subaru vehicles from about 1998 to at least 2007 (probably still similar), will constantly try to increase ignition timing in all load and rpm areas until light knock is detected, and then it will slightly retard timing, wash, repeat. This is how most modern EFI systems work. So a higher octane fuel will, in theory, allow for more ignition advance and this more tq for the same amount of fuel, all else equal. In practice, it does allow for the same amount of work (power) for less fuel/air or more work for the same amount of fuel/air. This is all well documented on at least a couple sources, of which romraider.org is the one I can recall.
    That said, without ECU logging data it's just opinions and feelings.
    2015WhiteOR likes this.
  7. Aug 27, 2020 at 6:13 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    87 w/ethanol.
    Tried 87 100% and it did get better mpg.
    Couldn’t tell a performance difference though, so I just went back to 87E
    I have used other ratings, but didn’t pay much attention to mpg or performance.
    Most of the time it was because I pushed the wrong button at the pump.
    Like when they put 87 between 89 and 91. That’s got me a few times, lol.
  8. Aug 27, 2020 at 6:54 PM
    rtilton12
    Robert
    Texas
    Premium fuel lasts longer too giving you more bang for you buck. Its a much cleaner burn too
    Rsmallw2[QUOTED] likes this.
  9. Aug 27, 2020 at 6:57 PM
    Bishop84
    Bishop84 Well-Known Member
    No it just allows for further timing. It doesn't burn any different. 91+ octane is for high performance engines with high compression or high intake temps that would detonate with regular fuel.
    91 in a Tacoma just means on heavy load it can run slightly high timing. Probably only noticeable towing.
  10. Aug 27, 2020 at 7:34 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I use the octane rating specified in the owners manual.
    crackils likes this.
  11. Aug 28, 2020 at 4:59 AM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Doesn't the owners manual specify a minimum 87 octane?
    Kolter45 and cryptolyme like this.
  12. Aug 28, 2020 at 5:09 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    89 runs the best in my 19 off-road with manual
  13. Aug 28, 2020 at 9:04 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    When paying more than 3$ a gallon the truck gets only the finest 87 e10 found here in CA
  14. Aug 28, 2020 at 9:10 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    85 here in CO - our octanes are all 2 lower than you filthy low-landers because we are so darn high all the time
    Kolter45, Tings, mray and 5 others like this.
  15. Aug 28, 2020 at 10:13 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    Cheap stuff day to day, Good stuff once in awhile with some sea foam. I do that mostly on a road trip, so it burns thru well and cleans things up.
    Chris(NJ) and davidstacoma like this.
  16. Aug 28, 2020 at 10:20 AM
    patos tacoma
    patos tacoma Well-Known Member
    when i first got my 2010 Taco. I ran 91, just to be nicer to engine etc........but noticed little difference......Now I run 87 in town, and for longer drives will put in 91, for the extra power on the Interstate , plus an injector cleaner or 2 because I know im going to be using lots of tankfuls......keep everything clean
  17. Aug 28, 2020 at 10:22 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Shell 89 mid grade mostly, sometimes 87 various brands
  18. Aug 28, 2020 at 10:22 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    According to Toyota you do make more power on 91
    rtilton12 and Rsmallw2 like this.
  19. Aug 28, 2020 at 10:33 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've got to run 91 octane because it has a supercharger
  20. Aug 28, 2020 at 1:59 PM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    87 works just fine for my "bone stock" 4.0L
    Kolter45, cwadej and Lester Lugnut like this.
