What octane do you run?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nicklamie132, Aug 27, 2020.
  1. Aug 28, 2020 at 2:01 PM
    TacoLyfe867
    TacoLyfe867 Well-Known Member
    Art
    2013 4x4 Tacoma TRD
    You dont get any pinging issues? I have to 91 or my truck sounds like shit.
  2. Aug 28, 2020 at 3:16 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If you can really hear that there is something wrong with your engine or sensors. If the knock sensor is working the ECU would pull timing and adjust to reduce knock until it's either not able to reduce it anymore or until knock is no longer detected. If the former, it would run like shit and there would be a light on due to trouble codes being triggered, probably for misfires.
  3. Aug 28, 2020 at 4:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Naw. HPtuners has helped lots there. Hardly any knock retard going on unless it gets hot out.
    Biscuits likes this.
  4. Aug 28, 2020 at 5:04 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    My 13 likes 89 best
  5. Aug 28, 2020 at 6:33 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I run premium which around here is mostly 91. The price difference at the end of the year really is not much. It was habit from my old Dakota where if I didn't run premium, it would knock under load. Most people waste more gas running under inflated tires than the difference in regular vs premium.
  6. Aug 28, 2020 at 7:06 PM
    CanadianYeti
    CanadianYeti Well-Known Member
    Kitchener, Ontario,Canada
    2014 TRD DCLB
    Shell 91 here in Canada, it's the only fuel that has no ethanol.. I run hybrid Camry taxi and have many years on regular fuel. One thing I can say is that I find is Toyotas knock sensors from factory are some what either dumbed down or relaxed.. with my truck or taxi the engines with ping on 87 fuel.. that pinging causes deposits in the valves and intake causing the engine to burn oil at an increasing amount... I have found that a Toyota engine run to 300k miles plus on 87 regular will start burning oil and will get worse, to the point adding a quart of oil every 600miles. I have found that switching to 91 non-ethanol will start reversing the oil consumption in a measurable way, that engine came down to a quart every 2000 miles.. until it was written off.. no further changes ;) My truck doesn't use oil but pings badly on 87 octane under light throttle. 91 eliminated that completely...
    davidstacoma likes this.
  7. Aug 28, 2020 at 7:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    87 Octane every time since new. No issues whatsoever. 2TR-FE Four cylinder FTW.
    sgage likes this.
  8. Aug 29, 2020 at 9:28 AM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    Gotta agree with Jimmyh. Never had any issues with pinging or performance or mileage or anything else over many years. Never tried a tank of 89 - afraid she might get spoiled :)
    Jimmyh[QUOTED] likes this.
  9. Aug 29, 2020 at 9:34 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    89 octane ethanol free is the ticket.
  10. Aug 29, 2020 at 10:06 AM
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
    I have a chemical engineering background in the petroleum industry. Putting a higher octane than the factory recommended on a stock engine is a waste of money. Premium fuel is not "better", cleaner, or more refined, and you cant get more power from it. Lower octane fuel is just as refined, pure, and clean as premium fuels. In fact, its the same "base" fuel, but high octane fuel actually burns slower to prevent detonation in high compression/performance engines. High octane gas also allows builders to add more timing, increasing performance without detonation.
    Again, using a higher than recommended grade (octane) on a factory stock engine yields 100% ZERO advantages....none.
  11. Aug 29, 2020 at 10:22 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    While I agree with you....I'll add 2 things. #1 At one point early on Toyota mentioned in the manual for the 4.0 that "for increased performance use a higher octane". #2 Some premium fuels like Shell V-Power have additional detergent additives that go well beyond the minimum requirements. So in the long run, there could be some benefit from a cleaner fuel system. I run V-Power in my wife's Corolla just for that reason. Has nothing to do with performance gains but rather her short-trip driving she often does. She works 1 mile from our house and shops about 3 miles from the house. That accounts for 90% of her driving. Her car doesn't get much opportunity to get out on the open road and clear it's self out. With as little fuel as she burns in a weeks time, I figure it couldn't hurt.
    ImMrCrash likes this.
  12. Aug 29, 2020 at 10:47 AM
    TRAVERSER
    TRAVERSER Well-Known Member
    Las Cruces NM
    2020 DCSB TRD OR 4x4
    I haven't noticed any difference running higher octane gas. Maybe since my truck currently has only 4k, it's still breaking in.
    I found this interesting video awhile back
    https://www.youtube.com/watch?v=Ro_XYDw9kSA
  13. Aug 29, 2020 at 11:09 AM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    I run 87 octane bought on base in San Diego. No issues.
    2011 Access cab V6 4x4
  14. Aug 29, 2020 at 1:44 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    This is not necessarily true. I'm not sometime who spouts the recommendation that people use higher octane fuel than recommended, and I would even argue that the benefit is not worth the cost in most vehicles that do benefit from higher than 87 octane fuel, but there are (small) benefits for many modern EFI based engines. Understanding how the knock correction and base ignition timing, advance igniting timing and/or total ignition timing is determined is key to understanding why higher octane can potentially improve tq and fuel efficiency. I'm not going to re explain it because I have twice already in this thread alone. It's easy to find here or many places on the internet if one desires.
    Another thing, while higher octane rated fuel may burn more slowly than lower octane rated fuel, the difference in rate of burn is negligible and has little to do with why it's good for engines that need it. The higher auto ignition temperature and flashpoint and overall higher resistance to ignition is why it's able to better prevent preignition, detonation/knock. The propagation speed of the flame front is such a small difference compared to things like cylinder pressure, fuel ratio, etc which effect flame propagation speed to a much greater extent.
  15. Aug 29, 2020 at 2:24 PM
    #35
    jedirye
    jedirye Wannabe
    Florida
    2013 Baja Supercharged
    Supercharger requires premium... :/
    Chayse, crackils and Biscuits like this.
  16. Aug 29, 2020 at 3:20 PM
    #36
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    A few more cents per gallon. Gotta pay to play. Besides, the supercharger is well worth it.
  17. Aug 30, 2020 at 7:03 AM
    #37
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    By now you’ve seen a few ignorant responses to this and it matters not that a petroleum engineer would try to explain this. They cling to their beliefs and superstitions and you see the same thing when it comes to motor oil. Been using and driving Toyota’s since mid 1970s. Been an aircraft mechanic for over 30 years. Use what the manufacturer says to use. It’s that simple.
    2015WhiteOR, cwadej and crackils like this.
  18. Aug 30, 2020 at 7:05 AM
    #38
    Bishop84
    Bishop84 Well-Known Member
    Have you tried avgas in your truck?
  19. Aug 30, 2020 at 11:31 AM
    #39
    cwadej
    Right Here
    2011 Access Cab 4x4
    I'm always amazed that swear because their pappy's neighbor did it he was smarter than the engineers who designed it and the company who built and warranted it.
    Gen2 Man[QUOTED] and Biscuits like this.
  20. Aug 30, 2020 at 11:49 AM
    #40
    Chayse
    Chayse Well-Known Member
    ABQ, NM
    2015 Tacoma Sport
    3" Procomp lift, 33" BFG's, TRD exhaust, and cold air intake.
    Supercharged 2015 Taco Sport. Now having to run Premium. Gotta pay to play!
    Biscuits and US Marine like this.
