What Octane do you use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 28ØØ3, Jul 9, 2009.
What Octane?
  1. 83
    11 vote(s)
    2.1%
  2. 85
    11 vote(s)
    2.1%
  3. 87
    284 vote(s)
    53.5%
  4. 89
    73 vote(s)
    13.7%
  5. 91
    75 vote(s)
    14.1%
  6. 93
    47 vote(s)
    8.9%
  7. 101
    1 vote(s)
    0.2%
  8. 110
    1 vote(s)
    0.2%
  9. 151
    4 vote(s)
    0.8%
  10. 215
    24 vote(s)
    4.5%
  1. Apr 2, 2010 at 7:54 PM
    #61
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    chris4x4 your peak HP should be more with 43 throttle body spacers, maybe you should recalibrate your second turbo to dump directly into both your 3rd turbo and your supercharger via a y pipe. this is what i saw done on TTORA.COM. also vertor adjustable intakes and exhaust ports will minimize drag and allow for faster speeds with the drag of supersonic speeds. your biggest problem at that point will be the door-sill wind deflectors tend to melt at about 1350-1430 MPH so you might want to remove those before using all 17 million horses you got.
  2. Apr 2, 2010 at 9:49 PM
    #62
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    all this talk of jet fuel-- i dont get it-- i just use tap water cause ITS FREE!!!
  3. Dec 20, 2013 at 6:52 PM
    #63
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    I used the mid grade about 80% of the time.. at least once every two weeks the high grade to clean out the lines.
  4. Dec 20, 2013 at 6:56 PM
    #64
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    92 octane in Hawaii
  5. Dec 20, 2013 at 7:26 PM
    #65
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Doesn't matter here. 87 or 91 and my junk still knocks around more then a battered spouse.
  6. Dec 20, 2013 at 8:24 PM
    #66
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Clean out the lines? All gas does that.
    Do you gas up every 3 days?
  7. Dec 20, 2013 at 8:38 PM
    #67
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I always use premium. I can get 91 no ethonal all over the place around here. What I don't understand is why people think premium is better simply because it has a higher octane rating. can someone explain that to me?
  8. Dec 20, 2013 at 9:11 PM
    #68
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The idea is that the higher the higher the octane rating the more steady and stable the burn is. Theoretically it's supposed to last longer too. However, given what I have ran into in my last two cars including this one. I would say the octane thing is a crock of shit.
  9. Dec 20, 2013 at 9:23 PM
    #69
    Eyedoc2020
    Eyedoc2020 Well-Known Member
    Greg
    DC suburbs
    2012 TRD Off Road
    Unfortunately I have to use 93 due to my engine knocking with lower grade gas...
  10. Dec 20, 2013 at 9:56 PM
    #70
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Unless you a running a high compression 4, 89-91 octane has zero benefit on a 4. I have actually heard through the grapevine that it can actually hurt your gas mileage.
  11. Dec 21, 2013 at 1:24 AM
    #71
    jsin
    jsin Member
    Florida
    2013 prerunner
    87 on all our vehicles.
  12. Dec 21, 2013 at 2:07 AM
    #72
    superdave
    superdave Active Member
    Dave
    St. Louis, Mo
    TRD Sport
    Camper Shell
    No, that was RUST that caused that! LOL
  13. Dec 21, 2013 at 12:35 PM
    #73
    western88
    western88 Chris b.
    ny countryside
    This is right. longs I don't go more than 65 mph.. I don't drive like a old fart.
    its cleans the nozzles of the injectors..
  14. Dec 21, 2013 at 12:37 PM
    #74
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    The cheapest...around here it's usually about 87
  15. Dec 21, 2013 at 12:57 PM
    #75
    smtaco73
    smtaco73 Well-Known Member
    South Louisiana
    2008 and 2009 TRD Sport 4x4 DCLB
    TOYOTA FAMILY Three Tacomas and one corolla.
    Non ethanol 95% of the time and if traveling I use premium. Have several non ethanol station around me
  16. Dec 21, 2013 at 3:48 PM
    #76
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    to get 91 octane refinery has to make another pass, that means fuel is cleaner. On the side note 91 allows engine to adjust and run leaner under the load with out knocking. That means you get to stay on high gear longer and on lower rpms. So if you drive normally you will get fuel savings. Truck will hit 20+ MPG on V6.
    However if you live in cold climate high octane is not best choice so once temperature drops below 50F its time to start switching to lower octane.
  17. Dec 21, 2013 at 6:08 PM
    #77
    worthywads
    wut?
  18. Dec 22, 2013 at 11:55 AM
    #78
    western88
    western88 Chris b.
    ny countryside
    eh? run another pass to make it cleaner????? does this fella BlueT knows what he talking about??? I used to work in the oil gas field.. so I am calling it BS.
  19. Dec 22, 2013 at 3:48 PM
    #79
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I swear mine hates 87, i run that 89 octane sex juice all day.
  20. Dec 22, 2013 at 3:51 PM
    #80
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    I use the type that gets me to work,normally 87, I reserve the good stuff for my older cars that used leaded gas.
