What Octane While Towing???
Discussion in 'Towing' started by Spoon93, Apr 25, 2018.
  1. Apr 25, 2018 at 11:28 AM
    Spoon93
    Spoon93 [OP] Well-Known Member
    Rogue valley
    06 DCSB SR5
    Read some info on several different websites including a Tundra website and basically:notsure:
    Would higher Octane gas help when towing 5k lbs? My truck is set up to handle it but I guess I started over thinking it and the interwebs have not helped :facepalm:
    This weekend I have a 200 mile round trip with 3 different passes that start at about 400-500ft and peak out around 2k feet. Not terrible but they're fairly quick up and down passes so the grade is fairly steep. I figure I'll hang with the semi's doing sub 45MPH.
  2. Apr 25, 2018 at 11:34 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Since you have an 06 your owners manual it might say this, the early 2nd gen manuals said that higher octance could be used for better performance. At some point toyota changed the manual to just "use 87" and didn't say anything at all about higher octane. End result is it might, maybe, possible give you a bit better performance but probably not.
  3. Apr 25, 2018 at 11:49 AM
    Spoon93
    Rogue valley
    06 DCSB SR5
    I have an Auto...and I do still have the original manual so I will take a peek at it. Thx
  4. Apr 25, 2018 at 11:59 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I’ve heard some people mention this but I have yet to hear a valid scientific argument for it.
    Higher octane fuel is intended to be for higher compression engines. Adding weight to the truck doesn’t improve cylander pressure... so... not sure why that is a thing to do.
    Plus I thought that higher octane = more ethanol, which = less fuel effeciency which = not a good idea in a midsize truck with a 21gal tank haha
  5. Apr 25, 2018 at 1:21 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I run 87 when towing my travel trailer and have no problem going +55mph in the mountains (my house is at 4,500ft and I tow over passes that are between 6,000 and 8,000ft).
  6. Apr 25, 2018 at 2:31 PM
    Spoon93
    Rogue valley
    06 DCSB SR5
    Perfect! Where I am going isn't that high up but if I head east or South out of Southern Oregon I easily go above 5k ft. Thanks for the info. @PackCon I thought the same thing you were thinking which is why I got so confused.
  7. Apr 25, 2018 at 2:35 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    If you are getting knocking or pinging when under a heavy load, then going to a higher octane would help. Otherwise, probably not. I suppose in theory the higher octane would give you slightly more torque as it has a slower burn, but the motor and ECU/ECM needs to be able to accommodate that. Higher octane doesn't mean more power, it just describes the burn rate.
    OnHartung'sRoad and 4WALKER like this.
  8. Apr 25, 2018 at 2:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Kodiakisland is right, but if your engine isnt knocking with regular, it shouldnt at higher elevation because that means the air is thinner- more space between the air molecules - so your cylinders cant take in the density of air as they can at lower elevations, so there is also lower pressure in your cylinders- so really, you can use lower octane fuel as well at higher elevations without getting knocking.
    The reverse of this is true when you super or turbocharge an engine; higher cylinder pressures typically need higher octane fuel.
