What off-road mods to be done first?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DirtDude, Mar 6, 2025.
  1. Mar 9, 2025 at 8:22 PM
    #41
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    And the air down tire pressure mod :thumbsup:
    Chew likes this.
  2. Mar 10, 2025 at 5:59 AM
    #42
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    First tires. Size and type desired compared to the stock size highway tire it comes with. More diameter means more total ground clearance, which is desirable. Know your stock wheel size too so you know your whole starting point. Thin is easier to fit in the wheel well.
    Second, remove or replace things underside that are just in the way of clearance- exhaust crossover reroute. It robs you of an inch+ of clearance for no reason. Rear U-bolt flip kit. The ubolt ends will drag bottom when wheels are in ruts. Get rid af any running board or step.
    Armor- I took my armorless, stock 1/2 ton trucks off road for 20 years by constantly stopping and spotting over small rock terrain however I was lucky too. Skid plates and sliders makes such process MUCH easier with peace of mind and makes bouldered terrain possible. Non-angled sliders double as a small step board.
  3. Mar 10, 2025 at 6:21 AM
    #43
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Yeah the stock U bolts do hang down a bit same with he exhaust hanging out the back - the tie rod sleeves .. . . . I was going to go with them but was advised against it - spindle gussets though definitely.
  4. Mar 10, 2025 at 2:20 PM
    #44
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Listening to some of these responses makes me think I need to upgrade to a M1A Abram’s before ever attempting a trail.
  5. Mar 10, 2025 at 2:52 PM
    #45
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Not *any* trail, just some of them. My truck is stock suspension and just an engine/transmission skid. Some trails would literally gut a Civic and did scrape my engine skid but I did finish them.
    Your biggest limit will be your confidence level and skill level. Sometimes it is best to turn back when it just starts to get challenging for you on any day or just for "today" (doped up on night-nurse/Vicks because of a cold or just because you have not enough time left in the day).
    dryheat likes this.
  6. Mar 10, 2025 at 3:13 PM
    #46
    RyanDCLB
    4/19 DCLBOR
    Right! Trail running vs rock crawling :rolleyes: For trail running, sliders and skid plate should do the trick! :D
  7. Mar 10, 2025 at 3:18 PM
    #47
    gudujarlson
    Minnesota
    I don’t consider trail running and rock crawling as different things. I think there are easy trails and hard trails. Hard trails often have a lot of rocks, but also steep inclines, mud, sand, big trees, and sharp corners.
    Waynebarkr and majpooper like this.
  8. Mar 10, 2025 at 3:23 PM
    #48
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    #1) The rear differential breather mod. Unless you will never cross a creek or mud hole over a foot deep!
    #2) Spare Tire Flip Over mod. So you can access the air stem!
    ##) Later, as needed, upgrade the shocks to Bilstein 5100s or better. Replace the tires with the tallest that will fit, without rubbing (265/75-16).
    *My Tacoma is a 2nd Gen Off Road 4x4, but these may still apply to 3rg Gens.
  9. Mar 10, 2025 at 3:28 PM
    #49
    gudujarlson
    Minnesota
    Skinny 33s on stock wheels fit just fine with no mods.
    In my limited experience, shocks make little or no difference, especially if we are talking about slow speed trail crawling. I’ve had SR5, OR, and King shocks. There is very little difference. I’m guessing there might a difference if I was doing high speed off-road endurance racing, but there is no opportunity for that where I live.
    I’ve seen custom made buggies with no shocks at all.
  10. Mar 10, 2025 at 4:50 PM
    #50
    David K
    Well, most of my four wheeling is in sand and long desert dirt roads... and large tires with fat sidewalls are needed.
    As soon as my stock Bilstein shock leaked, I replaced them. You don't drive off road without shocks... Your tires will hop and you shake the truck needlessly and will ruin the dirt roads for others (by washboarding them).
    FunknNasty likes this.
  11. Mar 11, 2025 at 6:59 AM
    #51
    gudujarlson
    Minnesota
    If you are on a dirt road then you are not off a road.
    MSN88longbed likes this.
  12. Mar 11, 2025 at 10:34 AM
    #52
    .45 Calibear
    .45 Calibear Well-Known Member
    Mount Diablo
    17 TRD Off Road - REI Crawler
    Broverlandering kinds
    Skids. First time I went out on a solo trip, I high centered on the crossmember. Didn't have a winch at the time and took me an hour of digging and stacking rocks.
    71tattooguy and Taco Egghead like this.
  13. Mar 12, 2025 at 12:50 PM
    #53
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    Yep - there are different forms off road . . . all which have different requirements. Just to mention a few:
    1.) overlanding - just getting to a primitive camp site or fishing hole.
    2.) desert racing
    3.) hard core rock crawling
    4.) trail riding - easy, intermediate, difficult and extreme the last two that can involve some rock crawling
    Chew likes this.
  14. Mar 12, 2025 at 12:59 PM
    #54
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I always tell people to think about how power transfers through the vehicle, start at the end (tires) and work your way back in. Good general rule of thumb for any car, off road, track, whatever. Tires should be first.
  15. Mar 13, 2025 at 2:07 PM
    #55
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    That is an excellent point. The very first thing I did was replace the stock Goodyears with 265/75R16 on a completely bone stock Off Road. When I was scarping my Predator steps on a trail rated easy I turned back. Talking to a few experienced off road guys they told me loose the steps as they are attached to the body (and probably were hanging down 3" or 4") and get some sliders that are bolted to the frame and while I was at it get a steel engine skid plate as the stock flimsy thing up front was almost useless. So that is what I did and stayed on easy rated trails at first then worked my up to intermediate trails. Completely stock suspension and 32s gaining experience and with the help of good spotters and more experienced off roaders.
    I have since lifted it with bigger tires, 5100s more armor and lots more and do more difficult trails with no problems
  16. Mar 15, 2025 at 5:11 PM
    #56
    TrailRunner18
    TrailRunner18 Member
    David
    2018 Black Tacoma TRD
    A good tool can be a kinetic rope as well. I had just a strap for years but struggled on some things with only a strap
  17. Mar 15, 2025 at 5:31 PM
    #57
    Bishop84
    Bishop84 Well-Known Member
    I always feel like kinetic isn’t a starter item. It’s a lot of force and it needs to be used by someone with a little bit of experience.
    they are better for sure.
    TrailRunner18[QUOTED] likes this.
  18. Mar 15, 2025 at 7:17 PM
    #58
    TrailRunner18
    David
    i agree, they definitely take a bit more thought. A snatch strap can be a good way to learn on a cheaper dime too for kinetic. wont last as long but you can get a semi close feel for it!
    Bishop84[QUOTED] likes this.
  19. Mar 15, 2025 at 7:43 PM
    #59
    Bishop84
    I've only needed a snatch once, and its usually because of stupidity haha I bombed through clay and mud, had a tacoma rescue my little jeep back in the day and saw how effective it was.
    For the most part I stay out of crazy stuff now, I've switched to 300lb bikes.
  20. Mar 15, 2025 at 8:28 PM
    #60
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Where i buy some common sense? Im running low
    TrailRunner18 and RDT415 like this.
