What oil and octane do YOU run in your Gen III Taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco 6x6, Dec 22, 2018.
  1. Dec 24, 2018 at 12:32 PM
    #101
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Just curious....why 91 with the OV tune? The tune can't change the engine's compression. Does it somehow keep the timing in a more advanced state? Does it interact with the knock sensors to keep things safe?
    Genuinely curious. I know nothing about the OVT.
  2. Dec 24, 2018 at 12:56 PM
    #102
    Plain Jane Taco
    USA
    You're doing no harm. In fact, if you look at the manual it says, "87 is the minimum octane rating" to be used. If using an octane higher than 87, the knock sensors will tell the ECM that it's ok to advance the timing a bit to compensate for the higher octanes tendency to ignite later in the combustion stroke.
    But, if you're in a high elevation part of Colorado....then you're truly wasting money...even more so than sea level people. Some high elevation people get away with 86 or even 85 octane because the engine's compression is lower at elevation...requiring even less octane to operate. Of course, the net effect of that is reduced power. But you can't change air density without some sort of forced induction. Or come back down to sea level.
    Stick with a Top Tier 87 fuel and put a little change in your pocket
  3. Dec 24, 2018 at 1:03 PM
    #103
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Plain Jane Taco likes this.
  4. Dec 24, 2018 at 1:19 PM
    #104
    Plain Jane Taco
    USA
    Beer:30[QUOTED] likes this.
  5. Dec 24, 2018 at 1:36 PM
    #105
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    87 gives noticeable power reduction compared to the 91 tune. Comparing the two 91 is the much better tune. This is 1.04 tune though.
  6. Dec 24, 2018 at 1:39 PM
    #106
    Plain Jane Taco
    USA
    Yeah....I know nothing about it. It has to be a timing thing. Or maybe a more aggressive throttle tip-in
  7. Dec 24, 2018 at 1:44 PM
    #107
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    Thanks i use shell and will go for 87 on my next fill up .
  8. Dec 24, 2018 at 1:51 PM
    #108
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I use the owners manual as a guide. 87 OCT, 0W/20, full synthetic. I know its a waste but change the oil and filter every 5000.MI. I sleep better.
  9. Dec 24, 2018 at 2:45 PM
    #109
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    I wonder why Toyota recommends 5k OCIs for severe service...that's literally the only thing causing me to "hedge" with EP for a 10k interval.
    While I don't beat on my truck, its almost exclusively used for short trips in a range of temperatures and occasionally tows a small camper.
  10. Dec 24, 2018 at 3:05 PM
    #110
    Plain Jane Taco
    USA
    For the severe duty use....they’re just playing it safe.
  11. Dec 24, 2018 at 3:07 PM
    #111
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Then we would argue which color looks best on Lada Niva, comrade : black, or off-white?
  12. Dec 24, 2018 at 3:32 PM
    #112
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    Fuel loading of the oil is the main issue with heavy loads (more likely to have more direct injection use and more fuel make its way into crankcase)and idling. The only way to fix fuel dilution is to dump it out. Another issue with direct injection is that it produces a soot that is smaller than a simple uoa can detect. This soot is however abrasive.
    My thought, I will change at 5k intervals until a lot of these10k interval fks’s reach 100k without needing a timing chain stretch fixed to see if toyota materials can beat the DI timing chain longevity odds.
    See the below reference articles and threads
    https://www.sciencedirect.com/science/article/pii/S0301679X15000432
    https://www.infineuminsight.com/articles/passenger-cars/timing-chain-wear/
    https://www.lubrizoladditives360.com/ilsac-add-timing-chain-wear-test-gf-6/
    http://www.import-car.com/timing-chain-wear/
    https://www.northamericanmotoring.c...13563-direct-injection-and-chain-stretch.html
    This is a quote from the above link.
    Direct Injection & Chain Stretch
    For those that do not wish to read the entire study I'll give you the cliff notes version before posting the link below. Some of this may seem counter intuitive to all the hype from the auto industry about direct injection. Just keep in mind that with traditional port injection the injectors can be open for
    1. Direct Injection results in a less homogeneous gas-phase mixing resulting in incomplete burning and clumping of particulates. In fact gasoline direct injection engines produce more soot than diesel engines equipped with a particulate filter.
    2. These soot particles invariably build up in the engine oil and increase the rate of wear. In point of fact chain "stretch" is considerably accelerated by elongation caused by wear of the chain pins and bushings.
    I think we can infer some solutions to help us happily motor on much longer.
    1. Change your oil more frequently. Yes, synthetic motor oil will in fact retain it's viscosity and lubrication properties much longer than conventional motor oil. But no matter how good the oil is it's not able to do it's job very well with a handful of sand thrown into it. As soot accumulates in the oil it will increase the rate of wear on the timing chain, main bearings, etc...
    2. Consider increasing your oil viscosity. Oil film thickness correlates to viscosity when measured in a kinematic or high shear rate viscometer. A thicker oil film will do a better job of preventing larger particles from abrading surfaces. Manufacturer's are constantly pursuing increased gas mileage and efficiency and many have lowered their recommend oil viscosity to further that goal.
    3. There's been some question as to if or why cryogenic treatment of the timing chain by some of our vendors (Detroit Tuned) results in less chain stretch. The short answer is that cyro treatment increases hardness and abrasion resistance. The conversion of austenite to martensite results in an increase of about 2 on the Rockwell hardness scale and the precipitation of Eta-carbides helps close the grain structure of the surface of the metal. Both combined will result in a longer lasting chain.
    Here's the full article for those interested.
    http://www.sciencedirect.com/science...01679X15000432
    Food for thought
    Pickeledpigsfeet likes this.
  13. Dec 24, 2018 at 3:47 PM
    #113
    Imphedup
    Imphedup Trout Addict Whitetail Killer
    CHAD
    LOWELL,MI
    2017 DCLB OR
    0/20 93
  14. Dec 24, 2018 at 5:17 PM
    #114
    taco woodeye
    taco woodeye Well-Known Member
    san jose CA
    2018 SR 4x2 Utility Delete Midnight Black Metallic.
    Castrol EDGE Professional
    LL IV FE 0W20.
    15-20k mile OCI.
    Costco 91 octane.
    83,000 miles on odometer.
  15. Dec 24, 2018 at 8:45 PM
    #115
    Invid
    2016 Tacoma Limited
    Check the official thread. I just know that the 91 tune out does the 87 tune as far as power goes, and that is not a seat of the pants thing.
  16. Dec 24, 2018 at 8:52 PM
    #116
    speedy112790
    speedy112790 Well-Known Member
    Stephen
    2016 Tacoma SR5 4x4 DC TSS LB
    10k oci dealer, 92 octane. Almost 30k miles original air filter lol
  17. Dec 24, 2018 at 10:36 PM
    #117
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    Royal Purple 0W20 for my first 2 oil changes. Probably switch to Mobil 1 (just because it's available at Costco) moving forward.
    92oct
  18. Dec 25, 2018 at 8:24 AM
    #118
    STPJ07
    STPJ07 Well-Known Member
    Florida
    2017 OR TRD 4x4
    Toyota 0W-20/ 93 OCT
  19. Dec 25, 2018 at 8:50 AM
    #119
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Redline 0w-20
    87 octane from 711 or ARCO.
  20. Dec 25, 2018 at 2:05 PM
    #120
    hordboy
    hordboy Active Member
    2018 T4R SR5
    I was running 87 in mine, then last tank I decided to try 89. Mileage instantly shot up from 19 hwy to 22, and it seemed to run a lot better. Less stuttering and soft misfiring. It had never, ever shown 22 on the meter before. Of course, this is right before I traded it off on a new 4runner. :O It was a very noticeable difference, not placebo. (I'm the biggest skeptic ever) Maybe the 87 I had been using was really crappy? I wish I had tried it earlier, but oh well.
