What oil brand do you use for your 3rd gen??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacotrd16, Oct 24, 2017.
  1. Oct 25, 2017 at 7:04 PM
    #41
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    I use Prestone power steering fluid. :thumbsup:
  2. Oct 25, 2017 at 9:26 PM
    #42
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    I've been using Amsoil in all my previous vehicles since the mid 1990's. Two diesel pickups, a Harley, 2 Yamaha sport bikes, and now my Tacoma. Have only done one oil change in the Tacoma so far, at just under 5,000 miles.
    Tacotrd16[OP] and Rambo54 like this.
  3. Oct 25, 2017 at 11:26 PM
    #43
    Tacotrd16
    Tacotrd16 [OP] Member
    16 tacoma trd off-road
    Rigid spot lights, relentless hood mounts.
    So is that a good thing or bad thing I wonder
    9TRDTCO likes this.
  4. Oct 26, 2017 at 7:24 AM
    #44
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good thing, I should have put in 17 years too.
  5. Oct 26, 2017 at 5:26 PM
    #45
    mavfox
    mavfox Well-Known Member
    SFL
    2013 AC TRDOR/07 FJC
    ARB Deluxe bullbar, OME 886 w/ Dakars, Warn Winch, Safari Snorkel, Tepui RTT.
    Vegetable oil
    Tacotrd16[OP] and over60 like this.
  6. Oct 26, 2017 at 5:58 PM
    #46
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I use Mobile 1 on my bicycle chain... Been running great for 55 years..... Just a little bit each week..!!
    Tacotrd16[OP] likes this.
  7. Oct 26, 2017 at 6:43 PM
    #47
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    never seen a motor blow up from changing the oil too often just saying.
    hr206, CusterFan and Tacotrd16[OP] like this.
  8. Oct 26, 2017 at 7:30 PM
    #48
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I go with Toyota’s branded oil and filters with dealer oil changes. First at 1150km, second at 8000km and third at 15,000km. (719m, 5000m and 9375m). At 15,000km I did a trani flush and fill.
    I do short trips to work (8.8km / 5.5m). I tow an 14’ enclosed trailer occasionally. So I consider my use to border on severe use even though for the most part it is it is pretty light duty.
    I know some may question my intervals and especially the trani flush and fill. This is my first new vehicle and I am unsure if I am going new again in a few years or keeping it forever or eventually turning it into a wheeler. Either way I am 100% in control of the maintenaince of this truck. If the trani issues some are having turn into something later (I requested the level checked at PDI and was assured it was done) I should definitely be covered now. This is all about doing what it takes to ensure my warrantee covers my ass and beyond that I know I will have the best maintained truck around if I do keep it long term.
  9. Oct 26, 2017 at 9:23 PM
    #49
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    Mobil 1 in crankcase with OEM filter and Valvoline synthetic in diffs. I saw the Blackstone lab results. Was that you? I learned a lot.
  10. Oct 27, 2017 at 1:42 AM
    #50
    Tacotrd16
    See you know what I’m talking about, I don’t get it. Would like to turbo my taco eventually.
  11. Oct 27, 2017 at 10:32 AM
    #51
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Rotella t6 0-40 in everything including generators,lawn mowers,cars,trucks,tractors....They all run quiet,smooth and clean. Might kill a cat converter after a few hundred thousand miles.
  12. Oct 27, 2017 at 10:24 PM
    #52
    verlaryder
    verlaryder Well-Known Member
    I'm a member of the Toyota 400,000 mile club and use genuine Toyota everything except for engine oil I use Mobil 1 10W-30 (5W-30 in winter) instead of the Toyota 0W-20 because all over the world (except the USA) Toyota owners manuals say it's OK to use 10W-30 in the 2TR-FE 4 cyl for temps above -10 degrees F and OK to use 15W-40 at temps above +10 degrees F. In other words, 0W-20 is a politically inspired viscosity (helps maximize fuel economy) rather than the best viscosity to minimize engine wear. I've used Mobil 1 ATF in the power steering systems of all my Toyotas since the 1980's and none have ever developed leaks or other problems.
    cseigh and Hoff like this.
  13. Oct 28, 2017 at 12:37 AM
    #53
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Soon will be 0W-16.
  14. May 5, 2018 at 5:09 PM
    #54
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    This guy put over 1000000 miles on his 07 V8 tundra putting i n nothing more then the cheepest thing the dealer can find, no $15 a quart amsoil or oil changes ever 3k. He just stuck to what the book said and when they tore the truck apart it was still rated a 7 out of 10. So I am not sure any of this makes a diffrance. Just put in any of the top brand stuff and do it every 10k and your fine.
    https://www.equipmentworld.com/this...figure-out-how-it-built-an-unbreakable-truck/
    Hoff and hr206 like this.
  15. May 5, 2018 at 5:13 PM
    #55
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    Mobil 1 Full syn
    Chipi3s likes this.
  16. May 5, 2018 at 5:16 PM
    #56
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Schaeffer’s
    KEFarm likes this.
  17. May 5, 2018 at 5:33 PM
    #57
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Valvoline everything but the front diff and T case. I use Supertech gear oil in those and change it every 20k miles since its under 30$ to change both.
  18. May 5, 2018 at 5:48 PM
    #58
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Toyotas typically don't burn oil. Why need a gauge?
    People typically obsess over oil brands and oil change intervals because of two reasons:
    1. It's one of the few things left that a weekend warrior can still do and understand and
    2. There is a grey area on intervals because garages want you to change it a lot ($$$$ for them) and most people's Dads changed it at 5K.. before synthetics.
    OP, get ANY brand 0W-20 and change it every 10K. You will go as many miles as you wish doing these two simple things. This is not a Subaru engine.
    Clearwater Bill likes this.
  19. May 5, 2018 at 6:02 PM
    #59
    shakerhood
    Southern Ohio
    Do any vehicles have oil level gauges, seems redundant since you have a dipstick to check.
  20. May 5, 2018 at 6:08 PM
    #60
    verlaryder
    He had to pay for two timing chain jobs at a cost of probably $2,500 in parts and labor each since the 2007 Tundra V8 has FOUR timing chains and tensioners. Thin viscosity oils have long been known to result in deminished timing chain life in Toyota engines.
