What oil brand do you use for your 3rd gen??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacotrd16, Oct 24, 2017.
  1. May 14, 2018 at 2:15 PM
    #141
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You forgot to quote the paragraph above yours haha:
    "Tribology is the science and engineering of interacting surfaces in relative motion. It includes the study and application of the principles of friction, lubrication and wear. Tribology is highly interdisciplinary. It draws on many academic fields, including physics, chemistry, materials science, biology and engineering. People who work in the field of tribology are referred to as tribologists."
    stun gun[QUOTED] likes this.
  2. May 14, 2018 at 2:32 PM
    #142
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Science. Check. Engineering of interacting surfaces in relative motion? Bet your ass there is. Principles of lubrication? Mos def. and I agree, it is HIGHLY interdisciplinary. I draw on my knowledge of all sorts of things when I’m at work. Materials science...aka “is this stuff gonna burn” personal interaction... “will my gf have a conniption if I use this all” duty cycles... knowing when enough is enough. Equipment failure etc
    hiPSI[QUOTED] likes this.
  3. May 14, 2018 at 2:45 PM
    #143
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Pistons in a bore, gear teeth meshing, chains around chain rings, bearings loaded up = interacting surfaces in relative motion!
  4. May 14, 2018 at 2:54 PM
    #144
    stun gun
    Aaronski
    Tacomas.
    Uh oh I feel a nap time coming on...
  5. May 14, 2018 at 3:05 PM
    #145
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Let me repost my dissertation on high velocity turbulent flow dynamics in various fluid conveyance devices..
  6. May 22, 2018 at 9:16 PM
    #146
    TacoTruckinTX
    TacoTruckinTX Member
    TJ
    Port Arthur, TX
    2015 dbl cab long bed V6 4.0L 4x4
    Bug guard, need bars, Snugtop camper shell, Yakima integrated rack.
    My 2015 Toyota Manual "recommends" using Top Tier rated gas. Www.toptiergas.com. These stations add additional cleaning agents beyond the minimum EPA requirements. I think it makes a difference especially if you plan to keep the truck for 10+ years. My plugs looked brand new at 30k(required change for emissions warranty). If I'm in the middle of nowhere ill buy if I'm below 1/8th tank, but 99% of time I buy from top tier rated stations. Running higher octane has no conclusive evidence that there is any benefit for engines designed for 87 octane.
  7. Nov 17, 2020 at 8:48 AM
    #147
    SandmanTRD
    SandmanTRD Well-Known Member
    AJ
    2018 Tacoma TRD OR QuickSand
    Cooper AT3 XLT 295/75/16 Method Double Standard wheels Eibach Pro lift Baja Design Fogs Baja design Ditch lights W/ Cali raised Lo pro Brackets WrapArmor Hood Decal
    First time doing my own maintenance on my 3rd gen (factory maintenance plan expired) My buddy had purchased a bulk order of royal purple and never used it. I was planning on using mobile 1 but he sold me 18 qts for 80 dollars. Just couldn’t refuse the deal. So now my question is, is anyone using royal purple? And is it safe to use 5-20w? I know the factory recommends 0-20w.
  8. Nov 17, 2020 at 8:52 AM
    #148
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I literally use whatever is the 0W-20 fully synthetic oil that is the cheapest at my local auto shop at the time. Last time, Mobil 1. Before that, it was Valvoline.
    BlkTaco47 likes this.
  9. Nov 17, 2020 at 8:56 AM
    #149
    dangeroso
    Jon
    Dallas, TX
    Are you in a pretty cold or warm climate? 5W-20 would perform more differently in a cold climate.
    https://carfromjapan.com/article/car-maintenance/0w20-vs-5w20-synthetic-motor-oil/
  10. Nov 17, 2020 at 8:58 AM
    #150
    SandmanTRD
    AJ
    Invid likes this.
  11. Nov 17, 2020 at 9:08 AM
    #151
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Amsoil signature series 0w-20.
    Amsoil exclusively since 1979.
    All climates from south Texas - central Minnesota - south California - north Georgia - east coast Florida - and now middle Colorado. Never a problem and always 25,000 change intervals (filter at 12,5k).
    SandmanTRD likes this.
  12. Nov 17, 2020 at 9:12 AM
    #152
    SandmanTRD
    AJ
    25k miles!? I haven’t seen anyone going that long. I thought I was pushing it at 9k!
  13. Nov 17, 2020 at 9:15 AM
    #153
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The manual states 5w-20 is ok in a pinch, but you should use 0w-20 in your next oil change, if I remember correctly.
    Junkhead and SandmanTRD[QUOTED] like this.
  14. Nov 17, 2020 at 9:18 AM
    #154
    RedWings44
    Michigan
  15. Nov 17, 2020 at 9:20 AM
    #155
    dangeroso
    Jon
    Dallas, TX
    You're probably fine then.
  16. Nov 17, 2020 at 9:21 AM
    #156
    RedWings44
    Michigan
    It just depends how you use it. But it's one of those things, "just because you can, doesn't mean you should." Personally, I still change mine every 5k. It's cheap maintenance. I've gone 10k before and didn't like the way it came out. I may try it again though since that was in my previous truck.
    SandmanTRD[QUOTED] and Junkhead like this.
  17. Nov 17, 2020 at 9:21 AM
    #157
    TartanEagle
    '17 ACLB 4x4 MT
    Never faltered. Even took advantage of their 36k authorized interval in my '93 Civic (290,00 on the clock now).
    Synthetic doesn't "wear out", but the additives will get consumed. With the filter change - and a new quart going in (to replace what was lost in the filter), the additive package is replenished. So if the engine is mechanically sound, the oil remains "good for continued service". That is a direct quote from Blackstone Labs.
    Invid likes this.
  18. Nov 17, 2020 at 9:23 AM
    #158
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Pennzoil Platinum which Walmart has here for $22 for a 5qt jug and a Mobil 1 filter.
    I previously used Mobil 1 in my '02 Tundra.
  19. Nov 17, 2020 at 9:29 AM
    #159
    TartanEagle
    '17 ACLB 4x4 MT
    Actually "you should".
    Against my nature to throw away good oil, to pollute the landfills, and to waste money.
    The truck sure isn't suffering from having quality oil in it. The labs confirm it is doing its' job for the whole duration. All my vehicles made it to over 260,000 miles before trading in on another one. Never a problem with any oil lubed system.
  20. Nov 17, 2020 at 9:29 AM
    #160
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I do mine every 5k as well. Comes out pitch black. Cheap and easy to do it yourself.
    RedWings44[QUOTED] likes this.
