What oil do you guys use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Whitelightning77, Jul 17, 2010.
  1. Jul 17, 2010 at 10:40 AM
    Whitelightning77
    Whitelightning77 [OP] Member
    Jake
    Driggs, Idaho
    1998 Tacoma extended cab trd
    Rims, hoe lights, sound system, tint, vent shades. Mostly all cosmetic right now. Can't wait to finally have it paid off, and start doing suspension and performance mods.
    I have a 1998 Tacoma sr5 v6 with a 189,000 miles. What oil would you use? It calls for 5w-30 on the cap, but a wise man once told me with high mile's run 10w-30. So I've been running 10w-30 penzzoil high mileage. What do you guys recommend? Thanks.
  2. Jul 17, 2010 at 10:49 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Mobil one synthetic 5w-30. Btw THERE IS NO REASON WHY YOU SHOULDN'T USE SYNTHETIC IN YOUR TRUCK.
  3. Jul 17, 2010 at 11:00 AM
    The_Dude
    The_Dude Well-Known Member
    There are countless threads on the subject, but to answer your question, it seems like Mobil 1 Synthetic 5w30 is by far the preferred product. I use Valvoline 10w30 Synthetic blend. Like you, a wise man told me that was the way to go but I am starting to consider the Mobil 1 myself.
  4. Jul 17, 2010 at 11:09 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    5 W 30 ( Dino) and whats on sale, I figure this way if you change it as recommeded in the owners manual you should be ok, regardless of the brand, look at all the traveling sales people that put 40-50 k miles a year on, they stop where ever Jiffy lube, Grease Monkey, bla bla bla, and those vehicles seem to run well over 100K miles. I don't drive the truck alot maybe 5-6 K a year and change it 2 times a year spring and fall.
  5. Jul 17, 2010 at 11:09 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    SEARCH. :annoyed:
  6. Jul 17, 2010 at 11:51 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    5w30 mobil 1 conventional, change er every 3000 miles
  7. Jul 17, 2010 at 11:51 AM
    Barnone
    Barnone Guest
    The slippery kind.
  8. Jul 17, 2010 at 12:44 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    I use Castrol GTX 5w-30 every 3,000mi. I have yet to be swayed by the synthetic mumbo jumbo.
    In your case I'd go with Castrol GTX High Mileage.
  9. Jul 17, 2010 at 1:02 PM
    Oskie_78
    Oskie_78 Well-Known Member
    Texas
    1998 4Runner, 2016 4Runner, 2023 Tacoma
    motor oil :p
  10. Jul 17, 2010 at 9:00 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    2004 TRD Offroad PreRunner 3.4L V6
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I use Chevron Supreme because it's cheap (when on sale at Costco) and it's supposed to be a high quality oil with a good additive package says the people at bobistheoilguy.com.
  11. Jul 17, 2010 at 9:44 PM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    10-40wt conventional or Synthetic, you can get it at Walmart Cheap. Mobil1 runs around $21 and Castrol synthetic $24. Conventional should be arounf 14 bones.
  12. Jul 17, 2010 at 10:54 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Amsoil 5w-30 synthetic.
  13. Jul 17, 2010 at 11:00 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Mobil1 5w-30
  14. Jul 17, 2010 at 11:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    x2 with a new toyota filter every 5K or so.
  15. Jul 18, 2010 at 12:01 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Royal Purple all the way
  16. Jul 18, 2010 at 6:21 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    Quaker State Q Horsepower,Walmart,Puralator Premium Plus Oversized filter too #20195 I think
  17. Jul 18, 2010 at 7:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  18. Jul 18, 2010 at 7:51 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    X1 with OEM filter every 4,000 miles, in fact changed it yesterday!
  19. Jul 18, 2010 at 8:59 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Pennzoil 5w30
  20. Jul 18, 2010 at 3:54 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Mobile 1 10w-30
