What oil for 2nd gen prerunner v6 4.0
Discussion in 'Technical Chat' started by Smallwallman, Nov 7, 2012.
  1. Nov 11, 2012 at 8:59 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    It's tucked in pretty high. Mine has the nipple on it and it still sits above my skid plate. Something would have to reach in, press in the valve handle, then turn it down.
  2. Nov 11, 2012 at 9:04 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I'm running 5w-30 Mobil 1 Extended performance with OEM Toyota filter. Just switched over from regular Mobil 1
  3. Nov 11, 2012 at 10:49 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Agreed, the valve is pretty stiff, it isn't "easy" to open and takes some effort. Certainly not impossible to image an accidental opening but not very likely.
  4. Nov 11, 2012 at 10:53 AM
    Av8er
    Av8er Well-Known Member
    Taylor
    Formaly Houston, now Tampa, FL.
    09 Prerunner SR5/TRD DC, LB, w/ Tow
    So is Amazon the best place you guys have found price wise for the fumoto valves? Considering one for my wife's '07 Honda Accordion 4cyl as well. ;) Pricey but seems to be a great idea.
  5. Nov 11, 2012 at 11:13 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    X2. I just put mine on last oil change so next time will be a piece of cake. Sits above my ato skid and thats with the nipple too. There was a group buy for them a while back. Cant remember what price they went for though.
  6. Nov 11, 2012 at 12:31 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Thanks guts, I will order mine now.
  7. Nov 11, 2012 at 1:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Watch your clearance on the Honda.
    I ran a Fram Sure-Drain on my Tundra because the bottom of the pan was pretty low IIRC.
    Duramax, the drain was horizontal on the back of the pan... the nippled Fumoto was perfect.
    '04 Rav4, like the Tundra, the drain is on the bottom corner of the pan and I'd be concerned about it hitting the ground... went with the Sure-Drain.
