What oil should I use? 2018 TRD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by truckstick101, Feb 2, 2018.
  1. Apr 3, 2018 at 11:42 AM
    #41
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    @CMillTacoma Why would you love to use 5W-30? I'm really trying to understand what benefit you are getting.
    Vbpiper and shakerhood like this.
  2. Apr 3, 2018 at 11:43 AM
    #42
    Woodrow F Call
    Colorful Colorado
    Yes. If you want, you can look at the effects of a 10,000 mile interval in one of the links in my signature.
    Vbpiper likes this.
  3. Apr 3, 2018 at 11:49 AM
    #43
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    Here's what to order if you want equivalent to Toyota USA OEM.
    Vbpiper and BillsSR5 like this.
  4. Apr 3, 2018 at 11:55 AM
    #44
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Apr 3, 2018 at 12:49 PM
    #45
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
  6. Apr 3, 2018 at 12:54 PM
    #46
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Use AmsOil Signature Series 0w-20.
    I used to think thicker oil protected better during cold start by sticking to the bearings. I researched it, I was wrong.
    Oil is too thick to lubricate properly when it's cold, lighter oil is better when the engine is cold.
    Vbpiper likes this.
  7. Apr 3, 2018 at 1:21 PM
    #47
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    I never was a believer in synthetic oil until I bought some from Amsoil for our Jeep JK. It made such a difference in engine noise and gas mileage that I only use Amsoil today. Changed out the oil in my new 2017 TRD Sport with Amsoil 0-20 signature series and experienced the same results. Never buying anything else going forward.
    cosmicfires likes this.
  8. Apr 3, 2018 at 10:50 PM
    #48
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Look for our engine equivalent in other countries and see what oil is recommended.
    My wife has a 17 Camry also with 0W-20. Same car is sold not only in the US. Look for the oil recommended for it.
    0W-20 is for CAFE/EPA appeasement.
  9. Apr 4, 2018 at 5:39 AM
    #49
    Woodrow F Call
    Colorful Colorado
    Yup.... I got 46,000 miles on my truck. I did the last two oil changes. All oil changes have been at 10,000 miles. I did not do a "engine break in" oil change. The last two changes showed no issues with bearings or oil degradation. It protects better at low temps than heavier weight oils do. I don't see ANY benefit in using a 5W-30 or heavier oil.
    All that in the name of better for gas mileage/emissions..... what's not to like and what benefit is it to use a heavier oil? Seriously, I want to understand.
  10. Apr 4, 2018 at 5:54 AM
    #50
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    5k oil changes that don't cost a ton and work fine for lube if thats the case.
    How do you know there's no issues with bearing wear?
  11. Apr 4, 2018 at 6:45 AM
    #51
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    He sent Oil Samples in and no bearing material in the oil.
    ChronicTaco likes this.
  12. Apr 4, 2018 at 6:49 AM
    #52
    CMillTacoma
    Craig
    Colorado
    2025 TRD OR Hybrid
    I missed that, thanks!
    shakerhood[QUOTED] likes this.
  13. Apr 4, 2018 at 10:17 AM
    #53
    Woodrow F Call
    Colorful Colorado
    What's the price difference between 2 5k oil changes and 1 10k oil change.
    If you have bearing wear issues, you will see it in the oil analysis. Click here for my last two tests. Oil analysis is pretty common in many industries and is used to determine when oil should be changed saving time, money, and issues related to working on equipment. You will always have some wear, but if you have bearing issues, you should see a step change or a gradual increase in the metals used to make your bearings.
  14. Apr 4, 2018 at 11:11 AM
    #54
    CMillTacoma
    Craig
    Colorado
    2025 TRD OR Hybrid
    Nothing really, I was simply concerned that the 10k would be to long for the oil since many have mentioned this was a simple EPA thing. I know that 5k oil changes work great from past experience and I have a tendency to stick with what I'm comfortable with.
    After looking at your info I'll feel fine making the leap for the 1st time to the 10k interval, thanks for your help!
  15. Apr 9, 2019 at 3:56 AM
    #55
    MassTaco'18
    MassTaco'18 MassTaco
    Adam
    New England
    2018 Tacoma TRD Sport
    ToyTec and IVD Suspension Tuff Stuff Delta RTT KBVoodoo rack
    People stressin' over oil weight! lol, it says 0w-20....go to wal mart, autozone, etc. and simply grab whatever 0w-20 that you want! Problem solved
  16. Apr 9, 2019 at 6:04 AM
    #56
    Xena1
    Ron
    Ever see any 0-20 racing oil?? I switched to 5-30 Amsoil SS as well.
    MassTaco'18 likes this.
  17. Apr 9, 2019 at 6:21 AM
    #57
    BillsSR5
    bill
    2014 SR5
    Walmart has Super Tech 0W16 available now:popcorn:
  18. Apr 9, 2019 at 6:26 AM
    #58
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I use leftover peanut oil from local donut shops. Works “wonders” on new motors. Smells awesome, but I get pulled over a lot.
  19. Apr 9, 2019 at 9:21 AM
    #59
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    Sams yesterday.....6 qt pkg for $28.95....Mobile 1 full synthetic
    MassTaco'18[QUOTED] likes this.
  20. Apr 9, 2019 at 9:37 AM
    #60
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    A few choices out there but almost all are not suitable for vehicles with catalytic converters, so before doing those access cab track days, remove the cats! :burnrubber:
