What OME coils to get?
Discussion in 'Suspension' started by vataco19, Jun 22, 2011.
  1. Jun 22, 2011 at 7:57 AM
    vataco19
    vataco19 [OP] Member
    i'm thinking about getting a toytec coil lift with the AAL rear. Should i get 886 coils if i plan to get an all pro bumper in the future or are the 885 coils fine?
  2. Jun 22, 2011 at 7:58 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    For the weight of the front bumper you will want the 886. Until you get the bumper the ride will be a bit stiff, I'm told.
  3. Jun 22, 2011 at 8:02 AM
    vataco19
    would the 885 coils work with an off road bumper also or just 886?
  4. Jun 22, 2011 at 8:05 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    How much does the bumper weigh and are you gonna add a winch ?
  5. Jun 22, 2011 at 8:12 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    The 886 coils are for extra weight. If your adding a bumper, winch, and armor you'll want the 886's. If your just adding the bumper I think you could get away with the 885's possibly.
    What are your plans for your truck?
  6. Jun 22, 2011 at 8:14 AM
    vataco19
    i havent decided on a certian bumper but definitly no winch
  7. Jun 22, 2011 at 8:15 AM
    vataco19
    the plan is probaby just the lift and possibly a bumper down the road. the bumper is mainly for deer, i seem to be a deer magnet. Im only 17 and have hit 1 deer and had 4 other close calls
  8. Jun 22, 2011 at 8:17 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    886's are for a lot of extra weight, like an ARB bumper and a winch. From what I gathered, the All-Pro bumper isn't overly heavy so unless you're really beefing up the truck's weight elsewhere or adding a winch, the 885's would do fine.
    From Toytec's website:
    Old Man Emu coils
    Select coils from options- All coils are sold in pairs
    -883 --- Front Coil Springs Used alone as leveling coils (approx. 1 1/2") for 07-09 FJ Cruiser, 05-09 Tacoma, & 03-09 4-Runner.
    The coils below are for 07-09 FJ Cruiser, 05-09 Tacoma, & 03-09 4-Runner.
    ---884--- 2" lift standard coils - add top plate spacers for full 3" lift
    ---885--- Medium 2" lift coils for 110 lbs additional front weight
    ----886--- Heavy 2" lift coils for 200+ front weight -- No top plate spacer needed--
    (Choose from options below)
    We recommend 90000 Old Man Emu shocks sold separately with 885 and 886 coils
  9. Jun 22, 2011 at 8:17 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  10. Jun 22, 2011 at 8:19 AM
    vataco19
    i would only add a semi-light front bumper so the 885's look like the way to go. thanks for the help guys
  11. Jun 22, 2011 at 8:23 AM
    OZ-T
    Peter North
    British Columbia
    I got 2 1/2" up front on my DCLB Sport 4x4 with 885's and no spacer .
    I chose the RelentlessFab aluminum front bumper because I got it mainly for deer protection as well , don't plan on a winch and it only weighs 55 lbs .
    That might be a good set up for you .
  12. Jun 22, 2011 at 8:29 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I agree with OZ, go with an aluminum bumper and 885's.
  13. Jun 22, 2011 at 8:31 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    886 and ARB.
    Fuck deer.
  14. Jun 22, 2011 at 3:04 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Vacaville, CA
    '13 STI Hatch\\
    Wonder if the same can be said about moose..
