What, or how much weight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marc70, Nov 18, 2017.
  1. Nov 18, 2017 at 5:16 AM
    Marc70
    Marc70 [OP] Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    I live in northern Ontario, and am curious what you carry for weight for traction in the winter, and about how much?
    I found some railroad tracks, >1' long, ~50lbs each. Used to carry 2, but thinking 4 now. What worries me about these is making a quick stop, and the damn things coming through the cab.
    Sand bags would probably be a better idea, eh?
    Anyways, just wanted to hear what others do.
  2. Nov 18, 2017 at 5:25 AM
    Pigpen
    Dan
    Northwest Montana
    I carry a lot of gear most of the time, but I've found that the weight of my fiberglass topper is sufficient for winter traction. Good tires are by far the best thing you can do for traction, but you should still have some weight on them.
  3. Nov 18, 2017 at 7:03 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    The railroad tracks would probably be OK if you could secure them.
    I've used sandbags before. About 300 pounds was great, but I found myself constantly taking them out so I could use the bed so I took it out.
    Something thin like a sheet of steel or a few horse stall mats would work.
  4. Nov 18, 2017 at 7:07 AM
    b_bednarz
    b_bednarz Active Member
    Ben
    Phoenix, AZ
    2008 Super White DCLB Prerunner TRD Sport
    TBD
    I used 300 lbs of sand in the winter when I lived in Upstate NY, it worked great for my 2wd ranger.
  5. Nov 18, 2017 at 9:15 AM
    Hoover
    Hoover Clear alcohol is for rich women on diets.
    Hoover
    Idaho
    2005 Tacoma TRD off-road
    RevTek & 5100s. Blocked on rear. K&N intake. Fog light mod. Flashlight holder. LED interior lights.
    I put in 2-3 tractor weights. Small and heavy as baby boo boo. They work great. Easy to store in the garage during summer. You can find them cheap on the classifieds. Or a tractor shop usually has some old ones laying around.
  6. Nov 18, 2017 at 10:35 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    On my old 2wd Mazda I used to have one of those Rubbermaid 50gal storage bins filled with sand, and boxed it in with 2x4s to prevent bent tailgate and whatnot. Super effective. I bet it was easily over 800lbs after getting water logged.
  7. Nov 18, 2017 at 10:54 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    i went with a more simple method. shovel some snow in the back. as the snow melts it will just melt away to. works mint
  8. Nov 18, 2017 at 10:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    2wd or 4wd?
    Do you run real winter tires?
  9. Nov 18, 2017 at 11:39 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    2 80lb bags of sand over the axle.
    I have a bed mat so they stay put.
    The tonneau keeps them dry so I have sand if needed.
    JoefromPTC likes this.
