What order?
Discussion in 'Audio & Video' started by Blaise22, Jun 14, 2009.
  1. Jun 14, 2009 at 7:46 AM
    Blaise22
    Blaise22 [OP] Well-Known Member
    Blaise
    California
    09 prerunner trd offroad
    Camburg 4.0 race spindles, coilovers, 285/75/16 Yokohama Geolanders mounted on 16" KMC Hoss wheels, Aero Turbine 2525
    I was just reading a how to and it said to put the fuse in and connect both battery terminals before you connect the rca and speaker wires. It said that if its all connected and then you charge your amp for the first time, the amp will try to draw its groung through your speakers and radio damaging them in the process. Is this true? I was under the impression that you connect everything, put the fuse in, and then connect the negative terminal.
  2. Jun 14, 2009 at 4:05 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    Put the fuse in last. You should have only had one battery terminal off anyway(the +).
    The amp does not draw power that way; through the speaker leads. There are capacitors in the amp that will initially need charged, but that takes all of a couple milliseconds and requires no special techniques.
    Just put the fuse in last and everything will be fine. Unless you have a short some where, but then how else were you going to find it? haha :D
  3. Jun 14, 2009 at 5:30 PM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    What ever you do...DO NOT let the magic smoke out of the amplifier.:eek:
  4. Jun 14, 2009 at 7:34 PM
    Blaise22
    Blaise
    California
    haha thats why im asking all these questions.. so ill keep the magic smoke in the amp and ill have a working sound system;)
