What other things to do when changing the timing belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Jul 24, 2022.
  1. Jul 24, 2022 at 9:55 AM
    5efvz
    5efvz [OP] Well-Known Member
    I'm the 3rd or 4th owner. Previous maintenance history is sketchy. What else should I tackle while I'm doing the belt change?
  2. Jul 24, 2022 at 9:57 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Cam seals and tensioner if you have cam sprocket tools available.
  3. Jul 24, 2022 at 9:58 AM
    Bishop84
    Bishop84 Well-Known Member
  4. Jul 24, 2022 at 10:03 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Water pump, idlers, front main seal, tensioner, cam seals as mentioned, probably radiator too since you pretty much have to take it out for work space.
  5. Jul 24, 2022 at 10:05 AM
    Madjik_Man
    Colorado Front Range
    Without knowing your engine, if you want to go OEM parts this is the best deal out there (this kit is for the 3.4L engine, make sure you buy the right kit for your engine):
    https://www.ebay.com/itm/180729034728
  6. Jul 24, 2022 at 3:13 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    If the service history is sketchy replace all the fluids.
