WHAT PART IS THIS?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pukabouy, Sep 23, 2010.
  1. Sep 23, 2010 at 5:00 PM
    pukabouy
    pukabouy [OP] New Member
    Tim
    Orlando
    2001 Toyota Tacoma Pre-Runner
    All,
    A loud buzzing noise is coming from this part. It is located underneath the center console.....I believe its a part of the Heater Unit. Please advise on what part this is and any recommended distributors.
    Thanks.
  2. Sep 23, 2010 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Inlet servo motor I think.....?
  3. Sep 23, 2010 at 6:55 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Second... I think.
  4. Sep 23, 2010 at 7:02 PM
    kilo
    kilo Solo Member
    San Antonio, Texas
    2007 Dbl cab long bed TRD Sport
    custom sliders, 3" Old Man Emu lift, onboard air, custom surf-rod mount, custom bed rack, ARB bumper, Budbuilt fuel tank skid-plate
    That's that thingymajiggy that lowers and raises your spare tire.:eek: What's it doing there??;)
  5. Sep 23, 2010 at 7:06 PM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    blend door actuator. i went through like 3 or 4 of them on my ranger
  6. Sep 23, 2010 at 8:36 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    x2 change those suckers on fords all the time.
  7. Sep 23, 2010 at 10:42 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    a what now?
  8. Sep 23, 2010 at 11:04 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    my parents 2000 Avalons was making a weird noise and it would just flutter and stuff. I took it off, tore it apart and re-indexed the spring and BAM! worked like a champ! Never had a problem with it again.
  9. Sep 23, 2010 at 11:17 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    A blend door actuator is what mixes the cold & hot air when you turn the temp knob. It blends the cold & hot air using a door, hence the name.
  10. Sep 24, 2010 at 6:42 AM
    AKTacoma
    Houma, Louisiana
    08 Tacoma DCLB
    ohhh I gotcha
  11. Sep 26, 2010 at 6:52 AM
    pukabouy
    Tim
    Orlando
    the parts guys at my local dealer called it a heater servo actuator, i asked if its the same as the blend door actuator and they looked at me like i was speaking greek...... which it is the same part. it costs $150 bucs so i passed and will try brelants recommendations or keep trolling the junk yards for one.
    Many Thanks!
