What performance rotors and pads to you run with stock calipers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruben526, Feb 24, 2018.
  1. Feb 24, 2018 at 11:33 AM
    Ruben526
    Ruben526 [OP] Well-Known Member
    Ruben
    Salem, Oregon
    2001 Tacoma SR5 Prerunner
    Solo MOTORSPORTS LT basic kit with king 2.5 8” coilovers Advanced fiberglass fenders all around Deaver J59 springs with rear shock relocation to outside frame 14” 2.5 sway away triple bypass sway away 2” 2.5 bump stops 35” general grabber X3 17” addicts Total chaos spindle gussets
    So I’m living in tehachapi right now (Mountain) between mojave and bakersfeild CA with that being said I have noticed my brakes and clippers reduced effectiveness with over heating but they are regular brakes & calipers nothing special. I’m looking to get something that could either help my braking power or reduce over heating. I heard that calipers with grooves/holes and such help with this sort of thing so I just want to get any of your input on the subject if you run the types of rotors I’m speaking of, what are the best brands etc.
  2. Feb 24, 2018 at 11:34 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Check out Frozen rotors.
    Ruben526[OP] likes this.
  3. Feb 24, 2018 at 11:37 AM
    Ruben526
    Ruben
    Salem, Oregon
    Just checked them out looks good they have the groves/slots I was speaking of which do you use?
  4. Feb 24, 2018 at 11:43 AM
    jrallan26
    Iowa
    Slotted
  5. Feb 24, 2018 at 11:44 AM
    jrallan26
    Iowa
    Are you from Torrance, Ca?
  6. Feb 24, 2018 at 12:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Tundra 13WL brake calipers are the way to go. They're 231mm which allow for much greater braking performance than any stock tacoma brake setup can handle.
    COMAtized99 likes this.
  7. Feb 24, 2018 at 12:23 PM
    Ruben526
    Ruben
    Salem, Oregon
    Yeah I’m from Torrance CA
    JDawg562 and jrallan26[QUOTED] like this.
  8. Feb 24, 2018 at 12:25 PM
    Ruben526
    Ruben
    Salem, Oregon
    I’m wanting to do this in the future too as I’m going to be switching to a tundra rear end eventually how much is the tundra front brake conversion about all together?
  9. Feb 24, 2018 at 12:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Ruben526[QUOTED][OP] likes this.
  10. Feb 24, 2018 at 1:54 PM
    Ruben526
    Ruben
    Salem, Oregon
    Just looked it up and everything I’m going to buy it I’m stoked now thanks man. Just to confirm this is the exact set up you bought for the truck right? And the new brake lines will fit my existing hardlines?
  11. Feb 24, 2018 at 1:55 PM
    jrallan26
    Iowa
    I grew up in Torrance.
  12. Feb 24, 2018 at 1:57 PM
    Ruben526
    Ruben
    Salem, Oregon
    Oh man you are a long way from home! Haha yeah I’m going to be moving back to torrance in about 6 months when my girl finishes her Respitory Therapy school in bakersfeild.
    jrallan26[QUOTED] likes this.
  13. Feb 24, 2018 at 1:59 PM
    jrallan26
    Iowa
    What part?
  14. Feb 24, 2018 at 2:09 PM
    Ruben526
    Ruben
    Salem, Oregon
    Closer to old Torrance / lomita area
  15. Feb 24, 2018 at 2:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I don't recall if that's the exact combo I bought. But here are the brake lines I used. Yes they're advertised for S13WE but they work for 13WL. LCE makes the only true stock replacement aftermartket SS brake line since everyone else uses banjo bolt brake lines and LCE uses the hard line flares lines. https://www.lceperformance.com/Stainless-Brake-Line-Kit-Tacom-To-Tundra-Upgrade-p/1055114.htm
    1997tacomav6 likes this.
  16. Feb 24, 2018 at 2:14 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Actually the only things I used from that kid were the calipers and pads, I bought performance Baer rotors as a package deal from a member on here.
    OH AND YOU MUST HAVE 16" WHEELS OR THESE WILL NOT FIT!
  17. Feb 24, 2018 at 4:21 PM
    Ruben526
    Ruben
    Salem, Oregon
    Alright awesome so those brake lines will connect straight to the tundra calipers correct? I don’t need anything else besides what you have told me?
    I like that LCE give you a 6” extension which I’ll need for my LT kit
  18. Feb 24, 2018 at 4:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes the LCE kit will have everything you need. You will need to cut your brake shields a little to make the bigger Calipers fit.
  19. Feb 24, 2018 at 8:51 PM
    Ruben526
    Ruben
    Salem, Oregon
    I was going to completely take it off anyway, thanks man can’t wait to do this upgrade
  20. Feb 25, 2018 at 1:10 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Maybe this is bad advise, but I'm using the stock Tacoma rubber line and banjo bolts. I used two of those washers between the banjo fitting and caliper. Has been that way for 2 years and 3-4 wheeling trips. Zero issues, and no leaks.
