What plug is this on an ATV?
Discussion in 'All Terrain Vehicles' started by RBoyd0325, Dec 30, 2012.
  1. Dec 30, 2012 at 3:06 PM
    RBoyd0325
    RBoyd0325 [OP] Well-Known Member
    Richard
    Alabama
    08 TRD Off Road 4x4 3" lift
    I have a 1988 Yamaha Moto-4 Big Bear, and when I was working on it one day, i noticed this plug. I had just drained all of the oil out of it, but when i removed the screw, oil came pumping out of it. It looked like motor oil, and not some sort of diff fluid. Im afraid to ride it now because i have no idea how old the oil is, or what it goes to. It almost looks like the transmission. But i dont know how i would change it because i dont know how to drain it or find the drain plug. i need someones expertise, it would be greatly appreciated. thanks
  2. Dec 30, 2012 at 3:14 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i’m going to take a guess and say it was trans oil. some atvs/dirt bikes use the same motor in the trans as they do in the motor. i know my honda crf150r uses the same oil in both motor and trans and they drain and fill separately.
    also you wont. go down to the local deal and ask the parts guys. maybe they will know or can look at it on the computer. be nice about it and if they are a good dealer they should help you out. and you should not have to take it in.
  3. Dec 30, 2012 at 3:18 PM
    RBoyd0325
    Richard
    Alabama
    yeah that was going to be a last resort for me, trailering it somewhere. i was so confused on how if it was the same oil, how i could drain the motor oil out, and when i removed that plug, it came pumping out! now whatever it is is low....and i dont know where to fill it up. cause if it pumps out, i would think that means its a low spot, so i dont know how to fill it up.
  4. Dec 30, 2012 at 3:33 PM
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
  5. Dec 30, 2012 at 3:43 PM
    RBoyd0325
    Richard
    Alabama
    So should I worry about keeping it full of oil? Or is it the motor oil that is coming out of there?
  6. Dec 30, 2012 at 3:48 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    It's probably a gear oil...was it pumping out fast? or kinda dribbling out? Yeah, I'd keep the oil level up on that though.
  7. Dec 30, 2012 at 3:52 PM
    RBoyd0325
    Richard
    Alabama
    It didn't look like a gear oil, like you would put in the diff. It was brown and looked just like motor oil. But the spout is angled upwards and when I took it off, it should out pretty fast, like it was the low spot and had a good bit of pressure on it
