What plugs are supercharged guys running?
Discussion in 'Performance and Tuning' started by 6xchamps, Nov 15, 2016.
  1. Dec 30, 2016 at 1:56 PM
    IdRatherBNTheSanJuans
    IdRatherBNTheSanJuans Well-Known Member
    Coe
    05 TRD Sport 4x4 DCLB
    Kings. JBAs. AllPro standards. Mastercraft CXT 255/85r16s
    Hey Torspd-thanks for the info! Unfortunately, whatever the problem with the truck is, it's it's more serious than just spark plugs. Mine looked good.
    Time to get home and get it torn apart!
    You may see a new thread here soon where I'll be asking for help as I tear into it.
    I run the highest octane I can fine. Usually it's 91 sometimes only 90. My truck is all stock except for Gadgets headers, banks exhaust, and TRD gen1 intake.
    Also Torspd, are you a mod over on XRU? I have a question about getting my membership to work over there. I will PM you if so?
  2. Jan 1, 2017 at 7:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am. PM me. You'll likely need to communicate with an administrator there.
  3. Mar 28, 2017 at 8:38 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Well shit. Just found this while looking at Denso's website! :D Amazon was recommending the IKH20 to me for my Tacoma. Apparently that's warmer than IKH22, which is warmer than IKH24.
    Denso doesn't have an online guide to tell you which plugs work for your vehicle like NGK does.
    I'm not supercharged though. Think it even matters for me?
  4. Mar 28, 2017 at 8:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah. Don't do it! Bad idea if you are NA!
  5. Mar 28, 2017 at 10:24 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Unclear. What is bad if I'm Naturally Aspirated? The colder spark plugs?
  6. Mar 28, 2017 at 11:47 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because we are supercharged, our engines run leaner due to the increase in additional air being forcefully induced through the intake. We require colder plugs so we can counteract the additional heat being created by the hotter combustion temperatures created by the supercharger. Your plugs recommended from the factory allow the engine to run optimal at the combustion temps being created by the natural air being introduced to the combustion chambers.
    In short. LEAVE THEM BE.
    Norton and Kyitty[QUOTED] like this.
  7. Mar 29, 2017 at 8:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  8. Apr 26, 2019 at 11:28 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
  9. Apr 26, 2019 at 11:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    22's for stock
    Biscuits likes this.
  10. Apr 26, 2019 at 12:09 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I have used Denso Iridium Tough VKH22 plugs.
  11. Jul 21, 2019 at 9:07 PM
    JasonSanz
    JasonSanz Member
    eon_blue likes this.
  12. Jul 22, 2019 at 11:49 AM
    eon_blue
    Azusa, CA
    Yes you want to run 2 step cooler plugs, so IK22 is where it's at.
    Stock plugs are IK16, they go up in increments of 2. Since there are no IK18 plugs you want to use IK22.
  13. Jul 22, 2019 at 11:55 AM
    JasonSanz
    JasonSanz Member
    I can’t seem to find any 22’s for my 2001
  14. Jul 22, 2019 at 12:00 PM
    eon_blue
    Azusa, CA
    At the bottom of this thread there's a "Products Discussed" portion with a link to some Denso IK22 plugs, those will work. It says "does not fit your vehicle" on Amazon but only because those are not the plugs that Toyota recommends in the manual, but that's because Toyota recommends the normal IK16 plugs that the non-supercharged 3.4l engine uses.
    They will work
  15. Jul 22, 2019 at 12:01 PM
    #35
    JasonSanz
    JasonSanz Member
    Ok so should I get the 22 or 24
  16. Jul 22, 2019 at 12:02 PM
    #36
    eon_blue
    Azusa, CA
    22...the IK24s are what the 2nd gen Tacoma supercharged guys run (I think) when they modify for more boost
  17. Jul 22, 2019 at 12:14 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    *IKH* For the 2nd Gens.
    eon_blue[QUOTED] likes this.
  18. Jul 22, 2019 at 1:36 PM
    #38
    JasonSanz
    JasonSanz Member
  19. Jul 22, 2019 at 1:40 PM
    #39
    eon_blue
    Azusa, CA
  20. Jul 27, 2019 at 5:24 AM
    #40
    Oomaxse
    Oomaxse Well-Known Member
    2003 Red Tacoma Stepside TRD
    Stock
