What Pressure BFG KO2 265/75r16 Load E
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Marc529, Oct 28, 2016.
  1. Oct 28, 2016 at 4:15 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Fully loaded with or without dem hos? I figure that bed can fit at least ten groupies.
    PROseur[QUOTED] likes this.
  2. Oct 28, 2016 at 4:18 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Ho's like these....
  3. Oct 28, 2016 at 4:19 PM
    0210
    Vancouver, BC
    The problem with being that low is that fat chicks can still get in.
  4. Oct 28, 2016 at 4:20 PM
    Bishop84
    Bishop84 Well-Known Member
    I run 29-30 on my E's. If I towed I would go to 40psi. I offroad at 12psi.
    Start with 35 and work up or down.
  5. Oct 28, 2016 at 4:22 PM
    0210
    Vancouver, BC
    I can't unsee that, but I've just permanently blocked that image with my ad blocker :D
    PROseur likes this.
  6. Oct 29, 2016 at 11:01 AM
    Marc529
    Marc529 [OP] Well-Known Member
    I asked a serious question so that I could get the best number from others that had experience. Thank you to all those that answered.
    But out of 25 post 17 idiots decided to crack jokes and post garbage about something else not on the topic. I will take my chill pill now.
    BTW I tried the chalk test and it did not work. I will try 35 lbs and see what happens. There seems to be no real authoritive info other than what the Max load is for such a tire.
    a400ryan and Siblue like this.
  7. Oct 29, 2016 at 11:20 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The Chalk Test-
    Inflate all tires to 40 psi cold. It is better to deflate to your pressure, as inflating up can yield lower psi results.
    Chalk tires. I recommend a bottle of carpenter's chalk.
    Run on flat surface 50' forward and reverse.
    Adjust psi until even wear.
    Add 10%.
    Adjust front-to-front deflection, inflating lower of two.
    Adjust rear-front deflection, inflating lower of two.
    Test drive at speed for 30 min.
    Pressure should not rise more than 10%.
    The Formula-
    The OEM Goodyear Kevlar 265/70/16/112 @ the recommended 30 psi, has a load capacity of 1,953 lbs after ISO metric-LT metric correction.
    The BFG KO2 LT/265/75/16/E @ 37 psi has a load capacity of 1,986 lbs(+/-1 psi=38 lbs).
    Inflate all tires to 37 PSI cold.
    Adjust front-front deflection, inflating lower of two.
    Adjust rear-front deflection, inflating the lower and deflating the higher equal amounts.
    Test drive for 30 minutes at speed.
  8. Oct 29, 2016 at 12:09 PM
    Marc529
    Thanks for a serious comment. I tried the chalk test with standard blackboard chalk and it did not show any differences from 50-30-lbs, always scuffed off even for a short distance.
    As you stated "BFG KO2 LT/265/75/16/E @ 37 psi has a load capacity of 1,986 lbs" but the truck weighs about 4500lbs so about 1125 per tire.
    I found some more information to lead me to fill to 38-39lbs. I also live in a hilly area which will also wear more on the sides of the tires. So for now I took very careful tread depth reading and will monitor them over the next few months.
    I have noticed I have lost the soft squishy ride of the stock tires, that to be expected. I am actually saving them as a summer set, rims and all.
  9. Oct 29, 2016 at 12:30 PM
    splitbolt
    NW Arkansas
    I also stated the OE tire has an adjusted load capacity of 1,953 lbs at 30 psi.
    Actual load capacity is inflated by the manufacturer for various reasons. Toyota seems to go with a x3 payload formula.
    If you were to inflate the OE tire to 1,125 lbs load capacity, you'd be at around 17 psi(extrapolated because it falls off the chart).
    If you were to inflate the BFG tire to 1,125 lbs load capacity, you'd be at around 14 psi(extrapolated because it falls off the chart).
  10. Oct 29, 2016 at 1:01 PM
    0210
    Vancouver, BC
    I think you need to revisit grade school math, mate. There are only two of us idiots here that contributed "not on the topic." Well, three if you count the guy asking for info that won't actually help him. With seventeen of us it would be a heck of a party!
    What didn't "work" about the chalk test? LOL
    IronPeak likes this.
  11. Oct 29, 2016 at 2:30 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    If you can't deal with that ... maybe don't Internet?
    Fernando likes this.
  12. Oct 29, 2016 at 2:32 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Boo. Shut up.
  13. Oct 29, 2016 at 2:55 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Cheer up bro
  14. Oct 29, 2016 at 6:59 PM
    Hammy68
    Hammy68 Member
    New Hampshire
    2017 Tacoma TRD Off Road DoubleCab
    Duratracs 265 75 16
    I'm running Duratracs in same size and did chalk test for a couple hundred miles. Ended up at 35 psi so far and that is what I ran them at on 07 also.
  15. Oct 30, 2016 at 3:45 PM
    #35
    JoeRacer302
    Joe
    Pasadena, CA
    I did the chalk test too and ended up with cold pressure of 33f 29r for my 265/75r16 C-load Duratracs. At operating temp this ends up around 35f 31r, which so far has been working well for me.
  16. Oct 30, 2016 at 3:48 PM
    #36
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    I went from about 33 to 43 and its a huge improvement. much less rolling resistance and acrually a better ride imo
  17. Nov 4, 2016 at 4:49 PM
    #37
    easyrider88
    easyrider88 Well-Known Member
    2017 Quicksand Tacoma DCSB OR 4X4
    Interesting
  18. Nov 28, 2016 at 10:51 AM
    #38
    ForestFever1
    ForestFever1 Well-Known Member
    Ted
    Mississippi
    2017 Quick Sand TRD4X4 0ffroad
    Bilstien coilovers Toytec AAL w/fox 2.0's Sway bar relocate Carrier bearing drop ECGS needle bearing delete 285/75/16 Dick Cepek Extreme Country
    Mine run 39-41 (265/75/16 KO2s) and the feedback compared to the stock is more than I expected. I was actually thinking of going lower before I saw this. Has anyone seen a video tutorial of a chalk test? I've seen it explained before like above, but I just don't get it. Kind of like IKEA instructions. Sure it says how to do it, but that means nothing to me in the real life application.
    Those who know always say it's easy, have a cookie, but I need to see it to understand what I'm looking for I guess.
  19. Nov 28, 2016 at 10:58 AM
    #39
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    BFGoodrich recommends 50 PSI in order to meet/exceed the load rating of the original stock tires as you are converting from a P tire to an LT Tire.
    dawhoo likes this.
  20. Nov 28, 2016 at 12:06 PM
    #40
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Lotus, are you Hongkongnese?
