What preventative maintenance should I do?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rdd11, Feb 29, 2012.
  1. Feb 29, 2012 at 1:34 PM
    rdd11
    rdd11 [OP] Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    I own an automotive shop and the guy who runs it for me is away so I'm running it for a few days. I just pulled it into an empty pay. Cleaned the throttle body. Cai hose and maf sensor? This all took about 15 minutes anything I
    Else I can do that might help it? I have two great mechanics here but was wondering what some actual taco owners think I should do.
    Yes I'm aware I know very little About vehicles and that I own a shop it was inhereted from my parents when they passes away. I'm a. Electrician by trade so I can do amazing things with it electrically lights and stuff but mechanically I'm useless but hopefully gonna learn some stuff
  2. Feb 29, 2012 at 1:39 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    top off all fluids, coolant, powersteering fluid, blinker fluid, etc.
  3. Feb 29, 2012 at 1:43 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Check that the hood scoop is still functioning and ATRAC is disabled
  4. Feb 29, 2012 at 2:10 PM
    rdd11
    Ross
    Red Deer, AB
    Switched and topped up every fluid in it cleaned the filter and new fuel filter. Blinker fluid? Your kidding right never heard of that haha
  5. Feb 29, 2012 at 2:35 PM
    mikedaz
    mikedaz Active Member
    NH.
    07 SR5 I4 4x4, access cab, 5 speed,
    bug deflector, vent guards, running boards ,stainless tip,summer + winter tires + wheels,secondary filter removed,60 series delta flowmaster,tow hitch,pop+lock
    Check the finagin pin,if worn or bent,replace!
  6. Feb 29, 2012 at 2:47 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    All depends on mileage and engine.
    If Applicable
    4wd service.
    Plugs
    Check brakes
    Do a rear brake clean and adj.
    lube all hinges
    lube drive shaft
    check filters ( cabin and air )
    Battery check clean battery and terminals if necessary.
    That will give you something to do for a while.
  7. Feb 29, 2012 at 3:04 PM
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Deflate the tires and then reinflate them. Do this to make sure the tires dont leak and the sensors work properly.
    Use your girls favorite sweater to buff the tailghts out.
    Check the light bulb connections, Turn on lights, remove bulb, insert tongue in the plug and hopefuly it works..lMAO
    READ THE MANUAL...
  8. Feb 29, 2012 at 3:05 PM
    Lazylegs
    Craig
    :cheers:
