What product to remove scratches from the plastic inserts behind the rear DC seats ?
Discussion in 'Detailing' started by OZ-T, Dec 23, 2012.
  1. Dec 23, 2012 at 9:37 PM
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
    Mothers Back to Black work or ?
  2. Dec 23, 2012 at 9:44 PM
    OZ-T
    Peter North
    British Columbia
    Interesting
  3. Dec 24, 2012 at 10:56 AM
    OZ-T
    Peter North
    British Columbia
    Tire Shine doesn't work
    Next idea
  4. Dec 24, 2012 at 11:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    STP Son-of-a-gun
  5. Dec 24, 2012 at 11:05 AM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    meguairs plastx
  6. Dec 24, 2012 at 11:05 AM
    monsterkx2fiddy
    for light scratches
  7. Dec 24, 2012 at 11:22 AM
    OZ-T
    Peter North
    British Columbia
    I tried Meguairs Plastic Polish too , that worked a bit but not entirely
  8. Dec 24, 2012 at 11:33 AM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I've read of heating the plastic to get rid of light scratches... never actually tried it though.
  9. Dec 24, 2012 at 11:39 AM
    OZ-T
    Peter North
    British Columbia
    Mothers Plastic Polish
  10. Dec 24, 2012 at 11:41 AM
    OZ-T
    Peter North
    British Columbia
    I thought about trying that too
    It's actually not a huge deal , I took out the inserts behind the rear seats of my DC and removed the cast in shelf from the passenger side , I was just looking to make it seem like the shelf was never there if possible
    The black plastic goes white when cut / sanded
  11. Dec 24, 2012 at 11:44 AM
    monsterkx2fiddy
    2000 grit sandpaper or finer and some plastic polish of your choice
    try a small area first
  12. Dec 24, 2012 at 11:46 AM
    OffroadToy
    more info... :)
    http://autopia.org/forum/car-detailing/57698-scratchs-black-plastic-interior.html
  13. Dec 24, 2012 at 11:46 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    On composite and PVC decking we use heat guns to remove light scratches and swirls etc. The only concern would be is if there is any texture at all, typically the heated plastic goes matte or even sometimes semi-gloss which will make is stick out. (Semi-gloss means to much heat was used.)
    Maybe try light heat gun with one of the recommended plastic touch ups?
  14. Dec 24, 2012 at 11:48 AM
    OZ-T
    Peter North
    British Columbia
    Thanks all
